Vert trunk lid latches
Old 10-14-2015, 09:09 PM
rcjays
rcjays's Avatar
Default Vert trunk lid latches
Do any of the c6 verts have automatic pull down latch closing systems on the trunk lid?
Old 10-14-2015, 09:12 PM
owc6
owc6's Avatar
Received 4,191 Likes on 2,681 Posts
No.
Old 10-14-2015, 10:46 PM
cclive
cclive's Avatar
No...but I can't imagine why one would be needed. I can simply drop my trunk lid and it will close all by itself in one movement. If it is not doing that, then the latch needs alignment. Mine also pops up fully without the need for an extra spring...again, it's an alignment issue if it doesn't do this.
Old 10-14-2015, 11:40 PM
rcjays
rcjays's Avatar
The reason I ask is because I was at the corvette museum today and was watching a guy demo the features of the c7. He was showing the trunk lid latch, which was a pull down. I commented that I wished the c6 has that feature. His comment was that it did! I said mine didn't he said his did an 08. I didn't want to argue with the EXPERT, but I knew he was wrong.
Old 10-15-2015, 12:02 AM
owc6
owc6's Avatar
Coupe=hatch. Vert=trunk. There does seem to be some confusion between the two, but not if you understand these two terms.
There is a both a C6 and C7 hatch pull-down. Still no trunk lid pull-down, then or now.
When brand-new, the trunks of both generations are very tight and hard to latch, but loosen up with use and age.
The hatch pull down is in fact new for the C7(old tech--some years of the C6 had the hatch pull-down, but new on the gen 7), probably because the vent pressure release gismo was a failure.
Old 10-15-2015, 06:18 PM
rcjays
rcjays's Avatar
It was a vert that he was demoing. A c7 and it had a truck lid pull down latch system. That's what got my attention! I can tell the difference between a vert and a coup.
Old 10-15-2015, 06:28 PM
owc6
owc6's Avatar
Well, this is brand-new, although very welcome news!
To Vert trunk lid latches
Quick Reply: Vert trunk lid latches
