Replace my ls2?
1. Summit sells a complete ls3 crate $6200. Is this the way to go?
2. I have my own programmer so I can flash a ls3 tune, but other than the better flowing manifolds, is this needed?
3. Any know issues with fitment of accessories?
4. Any major obstacles I'm not thinking of?
There was also a complete accessory kit (alternator, etc) cheaper than buying the parts separately.
We went from a 2006 LS2 A6 to a 2009 LS3 A6. The difference in power was surprising. The 2009 also got the performance axle ratio, but the engine itself seems great.
If we keep our C6 (now at 89k miles) long enough to run out the engine, we will probably replace with a crate LS3 if available.
I replaced my 2005 A4 LS2 with an LS3. It had developed a lifter issue; sounds about what you are dealing with at about the same miles (175,000).
I opted to go with a crate LS3 because it was going to cost almost the same to rebuild my existing motor, a crate LS2 or a crate LS3. The $6,200 is right in the same ball park as what I paid plus the labor. I had a few other issues at the same time that needed to be dealt with, so by the time I was done, I got a beefier radiator (which I recommend), a new A/C, and a few other minor things replaced. The exhaust had to retrofitted, as well (minor issue).
I have about 45,000 miles on the LS3 and could not be happier.
The added power is great. It idles rougher than the LS2, but no problem, once it was tweaked (normal from what I understand for the LS3). It also sounds better.
I'd be happy to answer any questions, if you like.
Removing/replacing the engine can be done in your garage with a cherry picker and just take your time. Mark or label stuff as you disassemble/disconnect it, as there are a lot more things to deal with than a '55 Chevy.
pulled the motor myself in my garage and no im not a mechanic, and yes it was my first time ever doing it . my motivation was the shops wanting 3k just to pull an reinstall the motor.
