Vitesse Throttle Controller Help.
Old Dec 15, 2015 | 04:01 PM
Z5108's Avatar
Z5108
Default Vitesse Throttle Controller Help.
Need help with removing gas pedal plug so I can install the hardware.
Is there a certain way to remove the plug been at it for 20 mins now.
Any tricks of the trades?
Not a lot of room to work with the tap on the gas pedal plug seem to be very small to push down on.
Old Dec 15, 2015 | 04:09 PM
Z5108's Avatar
Z5108
Do I need to remove the 2 screws 13mm bolt that hold the gas pedal in place?
Old Dec 15, 2015 | 04:26 PM
Not So Fast's Avatar
Not So Fast
https://www.corvetteforum.com/forums...oller-wow.html
NSF
Old Dec 15, 2015 | 05:55 PM
NashvilleGrandSport's Avatar
NashvilleGrandSport
You can if it makes it easier. The little gray clip on the plug on top of the throttle connection plugs slides up and out... a smsll.screwdriver might help. Then the two plugs disconnect.
Detailed instructions are on several threads. It's alot easier than apparently some people make it.
Old Dec 15, 2015 | 06:00 PM
JohnR2000's Avatar
JohnR2000
Be sure to remove the gray clip completely. Then you press in the center and pull upward which will separate the connector. I ended up removing the 2 bolts to the gas pedal which gives a much better view. Good Luck. You will like it.
Old Dec 15, 2015 | 06:20 PM
Not So Fast
If you would only go to the thread I posted above and look at #170 you will see exactly what to do !!!
NSF
Old Dec 15, 2015 | 07:24 PM
Zero_6's Avatar
Zero_6
https://www.corvetteforum.com/forums...ler-wow-9.html
Old Dec 15, 2015 | 07:29 PM
weathermaker's Avatar
weathermaker
NSF
The post # helped. There were 10 pages to that thread!
Old Dec 15, 2015 | 10:29 PM
Not So Fast
Glad to help, I knew it was in there cause I had read it all
NSF
Old Dec 20, 2015 | 06:53 PM
Z5108's Avatar
Z5108
Thank you everyone fir the help.
The instruction from V.T.C. needs to be clearer.
Old Dec 20, 2015 | 06:54 PM
Z5108's Avatar
Z5108
Car seems to be more torque. Very Responsive sp9 all day long..
Old Dec 20, 2015 | 06:57 PM
Proud Owner's Avatar
Proud Owner
Just purchased mine. This will give me 5 days to read about this easy install.
Old Dec 20, 2015 | 08:01 PM
Dcasole's Avatar
Dcasole
Just be careful with SP9 .... you will light them up in a heartbeat and when you might not least expect it ........
When I set mine on 9 it will spin easy 30 ft from the stomp and snap into 2nd real hard
Sometimes I back it down to 7
Dave
Dcasole's Avatar
Dcasole
If you need any help email me ...
Dave
Old Dec 20, 2015 | 08:04 PM
Proud Owner
Dave
Thank you. Looking at it it looks like the hardest part is getting underneath the dash. We were under there today since my Escort power wire came unplugged and could not find the connection. Did not really have the energy to find it. This will give me 2 reasons to pull everything out and get a clear view of what is under there.
Old Dec 20, 2015 | 08:10 PM
Dcasole's Avatar
Dcasole
It is easy , , pop the plastic plugs out of the black cover under the dash
And remember it is WAYYYYYYYYYYYYYYYY easier to drop the gas pedal to remove the harness than to try and fight it while its mounted
2 - 13MM bolts and its in your hand , remove the grey safety clip, swap the connectors , put the clip back on and then bolt it back to its mounting bracket ,
From start to finish should take you no longer than 30 minutes
Dave
Old Dec 20, 2015 | 10:09 PM
acheman8's Avatar
acheman8
Dave
Ya know, Dave, I had planned on doing that when I installed my controller, but there was no way in hell that I could see to get a socket on that top bolt. The pedal was in the way. I ended up getting the connectors apart by prying up on the gray clip with a small metal pick. It came right apart after that.
To Vitesse Throttle Controller Help.
Old Dec 20, 2015 | 10:12 PM
Proud Owner
Could a swivel be used on an extension to get to bolt?
Old Dec 20, 2015 | 10:16 PM
acheman8's Avatar
acheman8
Why, yes, I believe it could actually. Unfortunately I don't own one.
If I was doing it over, that's probably the first thing I'd go buy...
Old Dec 20, 2015 | 10:18 PM
Proud Owner
I have a multiple extension and swivel set from just being frustrated doing things like this. Options in a tool set is an awesome day
