Interior rattles
Old Dec 20, 2015 | 08:55 PM
don2000's Avatar
don2000
Default Interior rattles
Hello all. Just wondering what some of you have done to rid interior rattles. I'm very meticulous about interior rattles/noises. Mostly coming from the dash it seems. The dash doesn't appear to have ever been taken apart. My car is completely stock. Anything helps. Thanks!
Old Dec 20, 2015 | 09:17 PM
Meh Vette's Avatar
Meh Vette
Check the cluster area where the black plastic surround meets the clear plastic over the gauges. I shoved a piece of rubber in that area to stop my odd vibration noise by creating a gap.
Old Dec 20, 2015 | 09:24 PM
Dcasole's Avatar
Dcasole
Wow I have had my dash apart more times than I care to admit and I have zero rattles.... and this is with run flats
I just had it apart today to install my Ray Kawel aux 4 wiring and a usb glove box
And next week I am installing HUD
Something is not put together right . I can't think of anything that would cause a rattle if it's put together right
It's easy to pull the center stack and speedometer cluster to see what might be causing it
Pm me if you have questions on how to take it apart
Dave
Old Dec 20, 2015 | 09:41 PM
acheman8's Avatar
acheman8
I did essentially the same thing. Stuffed a length of rubber cord all along the small space between where the dash meets the gauge cluster. Worked like a champ...
Old Dec 20, 2015 | 10:07 PM
Boomer111's Avatar
Boomer111
I noticed creaks when I first purschases the 2008.
Going to non RF's and adding a thicker tunnel plate along with upgraded end links seems to have helped eliminate the more common mentioned sounds.
The front windshield cowling also vibrated, replaced.
No sounds coming from the cluster area though.
Maybe the advanced state of my hearing loss is a blessing in this regard.
Old Dec 20, 2015 | 10:12 PM
acheman8's Avatar
acheman8
Hey Boomer, how ya feeling about the big game? I'm more afraid of Clemson than Bama. Those type of teams (dual threat QB) typically give us fits. Do you ever post on LandThieves? If so, what's your ID?
Old Dec 21, 2015 | 07:17 AM
WW7's Avatar
WW7
I thought my dash was making noise, ended up being the front of the targa sqeaking and just sounded like the dash...WW
Old Dec 21, 2015 | 09:45 AM
Boomer111's Avatar
Boomer111
I don't have a horse in this race.
A Stanford Cardinal fan here!
No I am not on the mentioned site.
What the heck brought up this question? I rarely post on college football.
Clemson all the way, since you did ask.
Old Dec 21, 2015 | 11:27 AM
SpeedUp's Avatar
SpeedUp
My dash had some rattles, turns out it was the dash board vibrating against the windshield (around the hud). I stuck a piece of Velcro (fuzzy side) on the dash right up close so you could barely see it. Fixed that particular rattle.. so now I can move on to fixing other ones
Old Dec 21, 2015 | 12:07 PM
Yellow95's Avatar
Yellow95
The wife's '06 has a rattle. I thought it was the dash but it turns out to be the button on the shift lever. When it rattles, I just move it a little.
Old Dec 21, 2015 | 12:21 PM
Kenny94945's Avatar
Kenny94945
Foam, velcro, felt, double stick tape.
Take a passenger and start pressing panels/ areas to find the rattle.
Notorious areas, plastic panel at base of wind shield under wipers, A pillars, mini AC fan near the start button, header panel above mirror. Door panels are also notorious for rattling. There can be many more areas that rattle.
Good hunting.
Old Dec 21, 2015 | 01:12 PM
acheman8's Avatar
acheman8
My bad. I thought we had talked Oklahoma football in the past. Must have been another forum member with "boomer" in his name.
Old Dec 21, 2015 | 11:38 PM
owc6's Avatar
owc6
One common rattle happens when the visor is not snapped in. Another is the cowling (more of a hum, than a rattle, however).
Old Dec 22, 2015 | 12:21 AM
Vet Interested's Avatar
Vet Interested
My rattle is at the ash tray. Just when I think it is gone is shows up. Plastic on plastic I guess. Now it does not open. Just my luck
GO SOONERS!
Old Dec 22, 2015 | 12:23 AM
owc6's Avatar
owc6
GO SOONERS!
If the door ever opens again, you can remove the ashtray portion, or more likely, just snap it all the way back in.
Old Dec 22, 2015 | 12:25 AM
Welker1's Avatar
Welker1
I must be one of the lucky ones; over 90K on my '06 and no interior 'rattles' or noises so far (knock on wood). Can't say the same for some exterior noises that get my attention from time to time lol
Old Dec 22, 2015 | 12:29 AM
Vet Interested
Thanks.
It is looking like I will have to remove the complete assembly (as if I was removing the radio). Bummer!
Old Dec 22, 2015 | 12:34 AM
owc6's Avatar
owc6
Thanks.
Removing the center console is not that difficult. Even I have done it a few times.
To Interior rattles
