C6 Passenger Door Power Window Problem
Old Dec 21, 2015 | 08:25 PM
Mojoworkin's Avatar
Mojoworkin
2nd Gear
Default C6 Passenger Door Power Window Problem
Bought in 2004, garage kept with only 30K miles - surprised that this would happen with so little use!
Rolled the window down but when I tried to bring it up again, there was a grinding sound and the window stopped 80% up. Rolled it down again - no problem. Tried rolling it back up again, same grinding sound but this time iy only came up 75%. Decided a 3rd try would only make things worse.
Tried the service manual but couldn't find the cause/solution. Can anyone give me a clue what I will find when I pull the door panel and maybe the fix?
Old Dec 21, 2015 | 09:04 PM
HK770's Avatar
HK770
Are you not looking for C5 info if so your posting in wrong forum.
http://www.superchevy.com/how-to/140...rs-in-your-c5/
Old Dec 21, 2015 | 09:10 PM
Mojoworkin's Avatar
Mojoworkin
2nd Gear
Looking for C6. Bought the 2005 in late 2004.
Old Dec 22, 2015 | 01:16 AM
Kent1999's Avatar
Kent1999
not sure, but I think he could have bought a 2005 C6 in the fall of 2004.
Old Dec 22, 2015 | 02:18 AM
HK770's Avatar
HK770
Default Reading closer to the page!
After rereading Mojoworkins post, looks like I was wrong about posting in wrong forum.
This might be what is needed
https://www.corvetteforum.com/how-to...ctuator-368473
To C6 Passenger Door Power Window Problem
