Lifting Your Vette
Lifting Your Vette
I have done a lot of work on my vehicles over the years. But raising this Vette is more of a chore than I want to deal with. I have low profile jack and jack stands. Bought the lifting pucks other day. Other day I was going to replace cat back/axleback using boards and jack stands. After 40 minutes of trying I gave up. Not worth getting hurt or killed underneath any car so I took it to exhaust shop and had it installed. So I am thinking of getting this setup. Any member here have these?? http://myliftstand.com
Received 1,116 Likes
I guess if you install a new catback every month or so....but the maybe 2 times a year I jack mine up is not that much of a chore with jack and stands. Annual oil change is done with homemade 2x12 ramp.
If you do a search there are many of the shorty lifts on the forums, some look pretty neat and seem to be around $1500-$3000.
I considered it but then I said hey, how many times will I use it, maybe 1 -2 times then it will sit around collecting dust being in the way.
Now if I could have a real lift maybe
But I agree with the lifting of a Corvette being a big pain in the butt
Good luck
NSF
Good luck
NSF
Good luck
NSF
Good luck
NSF
It seems like a nice set up as long as you are not working on the brakes or wheels. I did a cat back replacement with ramps under the front and stands under the rear. I felt very safe and the car was secure. I did strap the front wheel to the stand so the car would not move when I got the rear wheels off the ground. Parking brake locks rear wheels.
jbc1995fb (01-28-2016)
I saw an interesting product in our local Tractor Supply Store (TSC) that I thought might be worth a try. It was a pair of aluminum heavy duty (3000 lb capacity) individual ramps for placing on a truck tailgate to drive riding mowers, ATV's etc into the bed of a pick up truck. Each was about 6-7" long. Seems like you could just place them on a 4x4" or 6x6" block of wood, or similar concrete block, and drive up on it. Would place the whole unit on the blocks however and not just the little end tabs that normally rest on the tail gate. Would have a very low entry angle, so shouldn't be a problem getting onto it. Would at least provide enough room to get under the car for an oil change. Any opinions?
Retired & lovin' it!
My garage ceiling is too low for a 4-post lift so went with a Kwik-Lift. Was able to by it used for a reasonable price. They come up for sale every once in a while either here on the Forum or Craigs List.
These are not that expensive. Was hoping to get some feed back of someone that have these. When possible I like to do my own work. All of my vehicles that I have owned always get lowered. This Vette needs to be lowered in the rear about 1/2" the rake is extreme. Also the rear drop will bring the nose up a bit. Tired of scraping.
Scraping and Corvette seems to go hand in hand
NSF
I use Rhine ramps, works pretty good. Jack the car up and slide them under the wheels. Changed out axle back exhaust using this method.
I did the stock bolt thing in the rear, had about 3/8" thread left to put pad in touch with the spring (left just the narrowest of a gap) and it finally has come down after settling the same amount, 3/8"+. Left the front alone.
NSF
NSF
I am not getting an alignment BTW
NSF
PS here ya go*** https://www.corvetteforum.com/how-to...orvette-369388
What is the weight rating on theses ramps? Could it be used for heavier vehicles?
http://www.bendpak.com/Shop-Equipmen...k/BL-5000.aspx
http://www.summitracing.com/parts/rnr-5175188 I've been pondering this for a while..
NSF
