Radiator
Old Jan 4, 2016 | 05:46 PM
BF Alexander's Avatar
BF Alexander
Default Radiator
My 08 Coupe needs a new radiator. Any idea what the replacement should cost ? Parts and labor ? And should I have the hoses replaced at that time ?
Old Jan 4, 2016 | 06:17 PM
Boomer111's Avatar
Boomer111
I would go with silicone hoses if replacing, and probably would be a good idea to replace anyway.
There is a forum vendor that sells complete hose kits: http://www.customcorvetteaccessories...iconehose.html
Look into using better clamps too. One that will not pinch in one area but clamp evenly. I believe the screw ones are the bad ones and the ones that need to be separated with plies are the good ones...search.
Also you might find this of interest: https://www.corvetteforum.com/forums...e-failure.html
Replacing the oem plastic "T" with a brass one.
Old Jan 4, 2016 | 06:34 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Contact Forum Vendor Gene Culley at CULTRAG for best OEM prices.
You may want to consider an upgrade to a DeWitts radiator.
Good advice on the hoses and clamps from Boomer111.
http://www.dewitts.com/collections/c...ts/c6-corvette
Old Jan 4, 2016 | 06:47 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Good advice above. If you're doing this yourself, you may want to consider other items on the front of the engine since the radiator's coming out such as the harmonic balancer. BTW, being an '08, was the coolant replaced a few years back (which is when it was due per Owner's Manual)?
Old Jan 4, 2016 | 06:57 PM
kedar's Avatar
kedar
St. Jude Donor '12
The radiator is not hard to replace yourself. The fan and radiator come out from the bottom (I guess they can come out together but I separated them). Upgrade to a Dewitt's radiator if possible. The plastic side tanks on the factory radiators are prone to cracking. If you do the job yourself, the toughest part will be separating the ac condenser from the radiator. If the current radiator is toast and will be discarded anyway then consider cracking off the plastic tab on the passenger side that holds the condenser. You can do this with a pair of pliers and a firm twist. The ac system does not need to be opened and the ac refrigerant does not need to be purged.
The plastic t fitting mentioned above may break during radiator removal so being ready for this with a brass fitting is a smart move.
I used breeze constant tension clamps on the upper and lower radiator hoses (these are much better than the standard worm clamp). I could not get a good seal using the factory spring clamps.
Old Jan 5, 2016 | 12:33 AM
HOXXOH's Avatar
HOXXOH
With no info in your profile, I don't know where you live. If it was in AZ, I'd offer a used '08 radiator (125K miles) and/or a used replacement (~1,000 miles) for really cheap.
Old Jan 5, 2016 | 08:04 PM
BF Alexander
Thanks for your help
BF Alexander
Old Jan 5, 2016 | 11:46 PM
Cherokee Nation's Avatar
Cherokee Nation
I had my replaced last month at the dealer..$218.00 for the radiator and 2 1/2 labor. I got gates hoses and clamps from O'Rillys...)08?Z51.....BTW.Those silicone hoses will cost more then the Radiator. They are fine if you show your vette.
Old Jan 6, 2016 | 12:02 AM
Dano523's Avatar
Dano523
Better question, how long do you plan on keeping the vet.
The DeWitts do not have the plastic ends, so no fear of down the road the OEM plastic end on breaking/leaking again, and start at $625.
The OEM style with plastic end caps can be had for around $112 is you don't need the model with the oil cooler for an automatic or Z51 engine oil cooler.
https://www.radiatorexpress.com/part...tepCompleted=5
Old Jan 6, 2016 | 09:23 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thank you for the referral. We would certainly be happy to help out.
Old Jan 6, 2016 | 09:42 PM
MikeERWNC's Avatar
MikeERWNC
I just did mine a month ago.
I found the best online price and my local dealership matched it and I was able to pick it up next day.
Research your car. There are two different radiators for the Corvette.
One with oil cooler and one without. Without is under 200.00. With is right around 400.00.
It was about a two hour job and can be done with a basic tool set.
If you are lucky, Chevy did not route the air bag sensor wire through you support bracket.
Everything comes out of the bottom of your car.
Disconnect your hoses up top then climb under the car and go to work.
Old Jan 6, 2016 | 10:51 PM
mikeCsix's Avatar
mikeCsix
I caution against installing a brass "T", you will be introducing a different metal into the cooling system and setting yourself up for electrolysis between the brass and aluminum engine/radiator.
I went with DeWitts, they are pricey but the quality is there plus there is extra cooling capacity for those really hot days.
Old Jan 6, 2016 | 11:21 PM
Cherokee Nation
Is your 08 a auto or manual?
Old Jan 13, 2016 | 05:55 PM
Cherokee Nation
It comes out from the top....
Old Jan 13, 2016 | 06:18 PM
Suns_PSD's Avatar
Suns_PSD
Guys I have a Ron Davis racing radiator in Texas. But I'm not going to use it after all. I would sell it for $360 + shipping, or pick up in Austin.
Old Jan 13, 2016 | 08:15 PM
JCOA's Avatar
JCOA
Off topic. Looks like a fairly new KTM in the background. Looking to pick up a 300 XC-W this year. Good fun. Wish I would have known about the Ron Davis you have for sale, before I had bought the DeWitts.
To Radiator
Old Jan 13, 2016 | 08:54 PM
MikeERWNC's Avatar
MikeERWNC
Maybe in your nation...
Here in Cherokee County it comes out easier from the bottom.
Old Jan 13, 2016 | 09:21 PM
kedar's Avatar
kedar
St. Jude Donor '12
Agreed, much easier to remove and replace the radiator from the bottom. Can be done on jack stands.
Old Jan 14, 2016 | 04:20 PM
Suns_PSD's Avatar
Suns_PSD
Here is the build on that bike if you are curious.
http://m.vitalmx.com/forums/Moto-Rel...-build,1253230
