Alright, stupid question. On my C6 it has the round steering wheel. I was just wondering if they ever made the flat bottom wheels for these cars? And if not is there anyway to convert the C7 wheel to work? ( I'm sure the plugs are different ). I have a 07 Z06
GM never installed a flat bottom wheel in production C6's.
IIRC, there was a member here who posted that the C7 wheel would not physically attach to the C6's column (different shaft size). Even if it could bolt on, it's highly likely that the electronics wouldn't be compatible.
A few aftermarket shops try to make the OEM steering wheel a 'flat bottom' by trimming off a tiny slice of the bottom outer edge... the result kinda sorta looks a little like a flat bottom wheel if you squint and are far enough away.
