Battery Replacement for GS in trunk area
I have a 2012 GS 6M with Dry Sump. I need to replace my battery and I have been running into issues. I believe that there's a bit of confusion when calling around to auto parts stores. Apparently when I provide my engine type and trim, they recommend a battery designed for the engine compartment. However the battery in a 2012 GS with Dry Sump is located in the trunk area and contains vent holes. Therefore, any battery that I purchase should have vent holes on the sides in order to plug the vent tube into. This allows harmful gasses to be expelled out of the vehicle and not into the cabin.
Here's my question.. does my GS have the same battery as the Z06? If so I can simply tell the parts store that I have a Z06 in order to eliminate confusion. In this case the battery should in fact have drain holes as the Z06 has its battery in the rear as well. I believe the GS did in fact come with the same battery as the Z06 but I'm not certain.
Next question.. what battery would you recommend that actually has vent holes on the side? Please provide a stock number if possible.
Thanks!!
Thanks!!
Yes. Same battery for GS dry sump and Z06.
I have a 2012 GS dry sump with the original battery as well, so I'll be in a similar situation soon. I'm typically a DieHard fan, but I've been thinking about going with a replacement OEM Delco battery -- given the lack of consensus on anything else being markedly better.
DATRUTH (02-07-2016)
You can also just bring your old battery with you to the auto parts store (there will be a core charge so you need the old one anyway) and find the correct battery yourself. Check the CCA, the size of the battery, the post type and post location. If all match your current battery, you are set. Do this even if you have a counter worker bring you what they say is the correct battery for your car.
DATRUTH (02-08-2016)
I changed out two of these last weekend for friends and got them from autozone and had no problems looking them up for a gs.you may have to move the hold down bolts up to the top notch to get the hold down back on if your height is different .
I just went through this too due to my stock battery leaking acid out of the positive post terminal. It was three years old anyway so it was on my to-do list. I went to the auto parts store looking for an AGM battery and it almost looked like a very powerful Group-34 would have fit.
The clerk and I wrangled out the old, even burning his hand a bit and then tried to fit the new but no matter how we tried, we couldn't angle it in due to a little indentation in the cubby. It's a shame because all the careful measurements said it would work and perhaps it would have by removing the trunk panels first.
A Group 35 battery is what's called for anyway so I ended up getting an Optima that fits fine and no need for the vent tube. It costs $244 at the parts store but I got mine from Amazon for $160 and a two-day wait. As Moman indicated, you'll have to modify your hold down a bit al though I just got a $5 generic one from the parts store.
Installed fine in Grand Sport rear cubby
If you want to loss some weight (20lbs), then here you go for under $100 instead.
Hence Deka ETX18L with Odyssey SAE terminals ODY-3217-0006
https://www.corvetteforum.com/forums...a-battery.html
Deka ETX18L
http://www.techbatterysolutions.com/...tm_term=ETX18L
http://www.summitracing.com/parts/od...FYSBaQodiCwDOw
P.S, this is an AGM battery, so make sure that you are using a battery tender that will maintain a AGM battery, hence something like a Ctek 3300!!!!!
Deka ETX18L
Those are great options, especially the Deka but there are other considerations when buying a battery I think. Anyone can buy a palm-sized race battery that will almost adequately start a Corvette and the weight savings is nice however, you're giving up reserve capacity. At least the yellow top weighs the same as stock, is an AGM and has a couple hundred more CCAs than stock.
Plus it'll continue to function even if I neglect it. With a race battery, it's just one more stressor I'd have to make sure I got right or stress out about it which I don't really want to get into. Plus, I don't want the alternator working hardcore, dragging my motor down, just to make up for a race battery.
I don't have my vent tube hooked up to my battery and have never smelled any strange smells coming from the battery. Not even sure my battery has vents in it, never paid any attention to it.
Hydrogen is colorless, odorless, and highly flammable. (think Hindenburg)
An engine compartment is usually too open for the gas to accumulate, but that often isn't true in the interior or in the battery well.
LMB-Z (03-17-2017)
I'm going with this one tonight, for my 2011 GS dry sump (battery in rear). They have a 20% off "buy it online, pick up in store" deal going, so it will be about $140 with tax and the old trade in.
http://shop.advanceautoparts.com/p/a...000%7CL3*15597
Edit - Advance Auto saved me a few bucks, they wanted to do their comprehensive test (battery/starter/alternator/etc) and it showed everything was OK. So I cancelled my battery order, and picked up a jug of Mobil 1 (with the Mobil filter) that is on sale this week, and called it an evening
So I just got off the phone with Optima battery and they stated they DO NOT RECCOMEND a non vented battery in the GS or ZR1. they said you need a vented battery and the Optima red or yellow is not vented. there battery could vent out into cabin if overcharging happens. Just what I'm being told. I'm in same boat with a GS looking for new battery.
Received 1,636 Likes
I went with a Die-Hard battery. Had the vent hole in the side and also an attached handle that made it easier to drop in place.
Optimas and other AGM's are sealed, but under high temps or overcharging conditions they will still vent out the safety ports. Some sactioning race bodies still required that ALL batteries be vented if mounted in the passenger compartment, even AGMs, which is why Optima doesn't recommend the Red or Yellow Top for the GS, Z06 or ZR1. 99.9% of the time it won't be a problem, but the 0.1% is all it takes to sue a company into bankruptcy. If you do an Optima (and many have) just be aware of that slim chance it will vent and that you may be DQ'd by a tech if you're into racing. Optima actually does have a few batteries that have vent ports (blue line?) but none that will fit our cubby hole. You'll also need to buy a different hold down strap because they're taller, but most auto parts stores keep those in stock for $5-10.
My dealer had the OEM battery within a couple of dollars of the others mentioned AND it has the vent tube. Lasted me 4 years on tender. Please post when you finally decide and replace it. We want to hear your bloody knuckle story...
Getting any battery out of the trunk cubby hole is a lot easier if you remove the hatch door. i think you just have to press in the pins and it comes out easily. Getting the OEM one out is easier if you can get one of those pivot/claw tools parts stores have to help customers install batteries, but worst case you can just Vise grip the battery terminals and pull straight up.
