Automatic Shifter Lock Up?
Thank you for providing GM's explanation.
It seems the pre-amble you quoted infers the problem is easily avoided if you give the system a few seconds to get in sync. However, we know that the assembly seems to be deteriorating due to stretching or temperature or something wearing down.
And, today, the dealer's cure was to replace the shifter assembly for $700 rather than to simply tell me to delay shifting out of Park.
It would seem GM should update their "Why It Happens" explanation to include comments regarding what leads up to the need to replace the shifter.
Anyway, I was hoping to understand what is actually changing. Had I read all the threads relating to this issue prior to my visit to the dealer today, I would have taken the time to press them for more information.
They told me they would diagnose the problem and if I decided not to get it fixed, they would charge me for the diagnosis. I told them to forget it. But, they did the "diagnosis" anyway and suggested I have them replace the shifter.
But, of course, to admit the design had to be changed, would be to admit there is an issue with it that could result in further consequences.
I plan to enter a "complaint" today at https://www-odi.nhtsa.dot.gov/VehicleComplaint/ . There are already several there regarding this subject.
What I've said was, that if I got stuck somewhere because of this problem I would cut the shifter boot apart and release the pawl in favor of getting it towed.
To tie the pawl back before the problem appears, or to cut the shifter boot as above and then fixing it later both require removing the console. Of course, I would have to buy a new boot with choice #2.
What I'd like to know: Is it possible to get at the pawl by cutting the boot?
https://www.corvetteforum.com/forums...k-finally.html
Post #18 in this thread shows how to remove the boot with the console off to gain access to the pawl.
Has anyone confirmed that the solenoid indeed weakens with time? I don't understand why the magnetic field of a coil of wire would "weaken". And if the coil went "Open" the problem would not be intermittent. Is there a chance the grease on the pawl or the solenoid core drys up and therefore friction is too great? Or maybe the plastic wears slightly and if the Pawl was filed some, it could be disengaged more easily from the assembly(?)
Assuming those ideas have no merit, I like the idea that one poster mentioned of drilling a hole in the pawl and bringing the wire back into the center console. Maybe use a guitar string and put a small black **** on the end? Then when the pawl locks, you would just pull the **** to unlock the assembly.
Seems crazy that we have to come up with this stuff rather than GM.
But I think that poster said that if you know exactly where it is, that you can manipulate it through the boot to unlock it.
Is this actually possible? Having never taken mine apart, I'm not sure by looking at all the pictures if this is possible. If it is, then that's all the "fix" we need -- especially for lazy people like me who don't want to take the console apart and do the permanent fix.
I now feel confident that if the car was stuck in Park while away from a set of tools, you could slice the boot and gain access to the location of the pawl. Although I think it wiser to make some sort of fix now with the console lifted rather than to slice your boot later.
