Index seats
On vehicles with the memory package, the controls are
located on the driver’s door.
1: Saves the seating position for driver 1.
2: Saves the seating position for driver 2.
B: Recalls the easy exit position.
The numbers on the back of the keyless access
transmitters correspond to the numbers on the memory
buttons.
To save seating positions in the memory:
1. Adjust the driver’s seat, both outside mirrors, and
the telescopic steering column to a comfortable
driving position.
2. Press and hold button 1 until two beeps let you
know that the position has been stored in the
memory.
A second seating, mirror, and telescopic steering
column position can be set by repeating the above steps
and pressing button 2.
To recall a memory position:
• On vehicles with an automatic transmission, press
and release the desired button.
If the vehicle is in PARK (P), a single beep sounds
and the memory position is recalled after a brief
delay.
If the vehicle is not in PARK (P), three beeps sound
and the memory position is not recalled.
• On vehicles with a manual transmission, when the
vehicle is on, the parking brake needs to be set to
recall the memory position. Press and release
the desired button.
A single beep sounds and the memory position is
recalled after a brief delay.
If the vehicle is on and the parking brake is not set,
three beeps sound and the memory position is
not recalled.
For vehicles with the Auto Memory Recall, see “Auto
Memory Recall” under DIC Vehicle Personalization
on page 3-72 for more information.
To stop recall movement of the memory feature at any
time, press one of the power seat controls, power
mirror or memory buttons, or the telescopic steering
column switch.
Easy Exit Seat
B(Easy Exit Seat): This button is used to program
and recall the desired driver’s seat exit position.
To program an exit position:
1. Recall the desired driving position by pressing
button 1.
2. Adjust the seat and the telescopic steering column
position to a comfortable exit position.
3. Press and hold the exit button until two beeps
sound to let you know that the exit position is
now programmed.
A second exit position can be programmed by repeating
the above steps and pressing button 2.
To recall an exit position:
• On vehicles with an automatic transmission, the
vehicle needs to be in PARK (P).
• On vehicles with a manual transmission, the
parking brake needs to be set.
B: Press to recall an exit position.
One beep will sound and the exit position for the
currently identified driver will be recalled.
For vehicles with the Auto Exit Recall, see “Auto Exit
Recall” under DIC Vehicle Personalization on page 3-72
