Vin decoder?
1G1YY26E285120819
Someone would have to have access to the GMVIS to look that up for you in order to be able to answer your question. There are some folks here who can do that. I cannot.
https://www.google.com/?gws_rd=ssl#q=1G1YY26E285120819+
As mentioned, it has an aftermarket unit, so it most likely didn't have the OEM NAV with BOSE.
You can try www.Compnine.com. They usually give you one free try at their Vin decoder for free, and it will show all the options.
The C6 BOSE system isn't all that great in a C6 anyway, likely affected by cabin noise.
http://www.autobidmaster.com/carfind..._CUCAMONGA_CA/
I looked at the difference in the color coded schematics between a BOSE and Non Bose, but for sure a BOSE AMP is needed with the added noise reduction microphone. BOSE speakers may also be needed.
There is also a FAQ section in the CF Audio/Electronic section that may have the answer your looking for.
https://www.corvetteforum.com/forums...audio-faq.html
Did you try to get a free Vin Decoded in
www.compnine.com
1G1YY26E285120819
Vehicle Information
VIN: 1G1YY26E285120819 Model: 1YY87-2008 CORVETTE Z06 2 DOOR
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Vehicle Build
Model: 1YY87-2008 CORVETTE Z06 2 DOOR Order Number: MNNJTC
Gross Vehicle Weight: 1,658 Build Date: 01/31/2008
Build Plant: 5
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
193 - EBONY 19I - BLACK INTERIOR TRIM
1SZ - PREFERRED EQUIPMENT SAVINGS 2LZ - 2LZ PREFERRED EQUIPMENT GROUP AM/FM STEREO, 6 DISC CD CHANGER, MP3 FORMAT, BOSE PREMIUM 7 SPEAKER SYSTEM, (REPLACES STD/OPT/PKG RADIO) PWR TELESCOPING STEERING WHEEL HEATED SEATS MEMORY PACKAGE UNIVERSAL HOME REMOTE SIDE IMPACT AIRBAGS, DRIVER AND PASSENGER LUGGAGE SHADE & PARCEL NET STEERING WHEEL RADIO CONTROLS ENHANCED ACOUSTIC PACKAGE
41U - BLACK AAB - MEMORY PACKAGE
AJ7 - AIR BAGS, FRONTAL & SIDE IMPACT, DRIVER & PASSENGER AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR
AQ9 - ADJUSTABLE SPORT BUCKET SEATS W/PERFORATED LEATHER INSERTS BGR - BOWLING GREEN PLANT
BS1 - INSULATION ACOUSTICAL PKG CJ2 - DUAL ZONE, ELECTRONIC A/C
D42 - LUGGAGE SHADE & PARCEL NET DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV FE4 - Z06 SUSPENSION
GU6 - REAR AXLE 3.42 RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
J56 - BRAKE SYSTEM POWER JJB - PT DRESS SUBASSEMBLY
JL5 - CONTROL MANUAL TRANS, 1ST TO 4TH GEAR SKIP SHIFT K63 - 110 AMP GENERATOR
KA1 - HEATED SEATS KNP - TRANSMISSION OIL COOLING SYSTEM
KNR - COOLING SYSTEM AXLE KPS - COOLER OIL, ENGINE
LS7 - 7.0 LITER 505 HP ENGINE DRY SUMP OIL SYSTEM MM6 - 6-SPEED MANUAL TRANSMISSION
MN6 - 6-SPEED MANUAL TRANSMISSION N37 - PWR TELESCOPING STEERING WHEEL
NC7 - FEDERAL EMISSIONS OVERRIDE NK4 - TILT LEATHER WRAP STNG WHEEL
NU1 - CAL EMISSION SYSTEM, LEV2 Q76 - Z06 CHROME ALUMINUM WHEELS
R6K - PROCESSING CODE R9N - PROCESSING CODE - SEAT
SLM - STOCK ORDERS U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
U3U - AM/FM STEREO, CD PLAYER, DVD NAVIGATION (REPLACES 6 DISC- -IN-DASH CD W/SINGLE DISC CD) U52 - ELECTRONIC INSTRUMENTATION
U65 - SPEAKER SYSTEM 7, PREMIUM UE1 - 1 YR ONSTAR SAFE & SOUND(ASK DLR ABOUT TURN-BY-TURN NAV UPGRADE)
UG1 - UNIVERSAL HOME REMOTE UJ9 - LOW TIRE PRESS. INDICATOR
UK3 - STEERING WHEEL CONTROLS US3 - ANTENNA DIVERSITY
UV6 - HEAD-UP DISPLAY V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
VA5 - ENGLISH LANGUAGE LABEL VDD - VEHICLE INFORMATION DVD
VH9 - ENVELOPE OWNER INFO MANUAL VK3 - FRONT LICENSE PLATE BRACKET
VT7 - OWNERS MANUAL ENGLISH XFA - FRONT TIRE - P275/35ZR18
YF5 - 50-STATE EMISSIONS YFJ - REAR TIRE - P325/30ZR19
I'll be swapping out my stock bose system here soon out of my 2010 gs
I'll be selling the system after I pull it out. But it's not gonna be for another month or so.
You can come check at the Abel show in May if I haven't taken it out yet.
Or you can come on the biggest cruise(rainbow run)of the year next weekend and check
It out
www.compnine.com
Vehicle Information
Vehicle Build
Build Plant: 5
Option Codes
It out
As for a price. I'm. It sure just yet I'll do research and see what set up are going for.
And the amp is in the passenger foot well under the dash. Next to the fuse box.
