You can remove the belt so the compressor wont be turned. The clutch will still be activated by HVAC system unless you press the snowflake button to turn off the compressor.
Why not just leave the belt on but don't turn on the A/C. Or is the compressor locking up on you? If so you could take the belt off the compressor.
But to be honest, I never checked out the diagram for the belts, so I'm not sure if you can go from one pulley to another leaving the A/C out. It maybe in the way.
