Vis question
Old May 16, 2016 | 05:18 PM
Aguita's Avatar
Aguita
Default Vis question
Hello, im a new member here and i just bought a 06 Z06, i would like to know
The service history for the car, i was told that theres a VIS that can be checked, does anyone knows where i can check this other than dealer?
The car got exported and local gm dealer cant verify this.
Old May 16, 2016 | 05:55 PM
4SUMERZ's Avatar
4SUMERZ
The VIS Report will give all the RPO codes, so if it is an import, that code will show it as such.
Your GM dealer can run the VIS for free. Get him to do it. All he has to do is put in the VIN #. It doesn't matter where the car came from to run a VIS Report.
You can contact Gene at Cultrag Performance. He may be able to get you a VIS Report and send it to your e-mail.
gene@cultragperformance.com
Good Luck
Old May 16, 2016 | 06:04 PM
Aguita's Avatar
Aguita
Thanks for the reply but i think i got it wrong, what i need is the report of the maintence records etc and what was done to the car, is there any way to check this?
Old May 16, 2016 | 06:08 PM
EVRose's Avatar
EVRose
You could try Carfax.
Old May 16, 2016 | 06:13 PM
4SUMERZ's Avatar
4SUMERZ
The VIS Report will also show you all the maintenance performed at any GM dealer. It also shows you the TSB's and recalls that were done, and any outstanding ones.
RicK T's Avatar
RicK T
The VIS can give you either or both, vehicle build info and/or claim history.
Post 2 in here is an EXAMPLE of a Claim History printout. Note that the lines aren't arranged correctly due to the copy-paste process. So you have to read it and section it in your mind. Or you could copy and paste it into a Word doc or similar and fix the line arrangement:
https://www.corvetteforum.com/forums...post1564232615
Old May 16, 2016 | 06:15 PM
Vette_DD's Avatar
Vette_DD
If the maintenance was not done at a Chevy dealer, I don't think it will show up on the VIS.
Old May 16, 2016 | 06:24 PM
Yaupon's Avatar
Yaupon
VIS only indicates warranty work that has been done to car, i.e., not any maintenance work. Carfax might show maintenance work done at a dealership, but not any non-dealership work.
Old May 16, 2016 | 10:06 PM
owc6's Avatar
owc6
Carfax is a big-fat-joke.
Old May 16, 2016 | 10:26 PM
EVRose's Avatar
EVRose
It actually gave a lot of info when I checked mine on there. Before and after I bought it.
Old May 16, 2016 | 10:36 PM
owc6's Avatar
owc6
Perhaps, but not everyone reports to it, so a negative report means nothing, and a positive report may or may be not correct.
My two C6s have had a collective six accidents, none of which were reported.
Old May 16, 2016 | 10:40 PM
COMMANDER2OOO's Avatar
COMMANDER2OOO
2017 Corvette of Year Finalist
2016 C5 of Year Finalist
Most corvette owners do there own maintenance anyway, at the very least change there own oil.
Old May 16, 2016 | 10:58 PM
owc6's Avatar
owc6
That's an exaggeration.
Most do not change their own oil. Perhaps, a higher percentage of Corvette owners change their own oil than, say, Focus or Prius drivers do, but I doubt that even most of the posters here change their own oil. Let alone the average Corvette driver who has never even cared enough to ask a question about their car. Which is the vast majority of Corvette owners.
Otherwise they'd be posters here.
Old May 16, 2016 | 11:39 PM
Aguita's Avatar
Aguita
I did but dont show maintenance other than putting new tires
Thats what im looking for maintenance done on dealer
thats what im looking for, other than that it shows that my car was 1 owner from new until 19k miles, currently it has 23k when it was exported from FL
Old May 17, 2016 | 09:57 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I tend to agree w. Yaupon: the VIS report doesn't show maintenance work done at a dealer (obviously it won't show work done outside of a dealer). It shows warranty, TSB, etc. type of work that is required or suggested by GM. The VIS can also show if a car has had some form of denial of a warranty claim---meaning, an owner came in for a claim and the dealer found something had been changed on/in the car such as equipment was added. Finally, the only place to get the VIS report which is free, is from a GM dealer.
Old May 17, 2016 | 11:26 AM
EVRose's Avatar
EVRose
Carfax does show maintenance work done at the dealer but sometimes it's very vague.
Here's mine.
Old May 17, 2016 | 01:40 PM
beachcomber's Avatar
beachcomber
[QUOTE=EVRose;1592232497]Carfax does show maintenance work done at the dealer but sometimes it's very vague.
Here's mine.
Very cool, great detail for carfax. But I find this is the exception from my perspective. That's
To Vis question
