Volume control problem
Old Jun 4, 2016 | 06:33 PM
trapshooter6's Avatar
trapshooter6
4th Gear
Default Volume control problem
Anyone had a problem with the audio volume control in their C6? The control **** turns but does nothing. The steering wheel control still functions.
Old Jun 4, 2016 | 11:52 PM
Dano523's Avatar
Dano523
Yep, and an easy fix.
You have to pull the radio out of the car, remove the front plate from the radio (screws on the side of the face plate) and remove it's front board (ribbon wires will unplug to remove them), and you will be staring at two potmeters on the board (volume pot is labeled 15452).
Note, the volume potmeter is attached to the front plate via a small board of it own (Board labeled gmx245, A2C53091187, but going to be hard to find the pot and board as a replacement unit alone.
The easier of the two is just to de-solder the volume/on-off potmeters and solder a new replacement on in (mouser electronics has them for a few dollars each).
But if it's dark thirty on a sunday night, and figure what the hell since you don't want to wait for the new pots, then you can pull the potmeters part to fix it isntead.
Once in hand and un-soldered from the board, unbend the bottom clips, and you will have the shaft section in one hand, and the bottom housing piece in the other. On the very bottom of the lower housing part, there is two wire clips, that a rubber cup type piece with center metal section pushes in via the shaft section to turn the radio on and on.
On the shaft section, there is a star type wheel on the shaft section and it clicks against tabs on the lower housing. This is where the problem in, hence the lower rubber plunger is starting to fall apart, and parts of it's rubber that fell off from the lower plunger is blocking the star wheel contacts from making contacts with the terminal prongs.
Depending on how bad the bottom section plunger cup piece is falling apart (now much spring you still have left with the shaft pushing it self back out), you can either clean and reuse it, or just replace it isntead (key board key type plungers work if you find you just happen to have the right size one handy).
Once you are done, put the potmeter back together, bend the bottom tabs back over, and re-solder it back to the board, and put the radio back together, and back in the car.
Old Mar 12, 2017 | 09:24 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Should be a sticky, great fix!!
Thank You
Old Mar 12, 2017 | 10:20 PM
Vette_DD's Avatar
Vette_DD
Thank You
Not very many people have a problem with this. Stickies usually get reserved for things like recalls, where several thousand people have a problem with something.
Old Mar 12, 2017 | 10:47 PM
919cw313's Avatar
919cw313
2018 C6 of Year Finalist
^ And important stuff like two threads for the 427 edition and one for some seven cR run edition...
Old Mar 13, 2017 | 01:32 PM
gmtech1234's Avatar
gmtech1234
My volume **** is eratic. Sometimes a small movement of it may result in a normal or greater result in volume either up or down. Does this apply to me?
Old Mar 13, 2017 | 02:28 PM
Hells's Avatar
Hells
St. Jude Donor '08
Same thing happens to mine. I figure it's probably time for a new head unit.
Old Oct 15, 2017 | 04:13 PM
gmtech1234's Avatar
gmtech1234
Cleaned my volume control on the radio with cantact cleaner. Let it dry, volume works like new. Removed radio & **** to access. Could be done in car, just remove ****.
Old Oct 15, 2017 | 05:12 PM
Vette_DD's Avatar
Vette_DD
Right. 1978 posts and 232,226 views for one 427 thread, 2623 posts and 274,043 views for the other one.
Old Jun 25, 2019 | 10:16 AM
luka2sb's Avatar
luka2sb
Yes i know this is 3 year old thread, but this is the closest i could find to an answer.
Can anyone please give me the part number to replace the radio volume potentiometer for a C6 corvette radio.
Old Aug 7, 2019 | 11:20 AM
about2rock's Avatar
about2rock
Were you able to clean the volume control by only removing the ****? If so, what is the best way to remove the **** without removing the radio and faceplate?
Thanks!
Old Aug 22, 2019 | 10:34 AM
Wifesride1's Avatar
Wifesride1
1st Gear
Default Radio volume control
Is there any chance you would have the part # you ordered from Mouser Electronics? I was on the phone with a tech named Tim and he wasn’t able to help me out, after passing on your info to him.
Old Sep 24, 2024 | 11:38 PM
Felixllamas20's Avatar
Felixllamas20
Navigator
I hate to comment on such an old thread but I had this problem and I fixed it myself! I ordered the part on amazon! Perhaps you already fixed this issue but for those who happen to want to tackle this issue…I will put the link here https://a.co/d/7osMLWb
you will need to take the front plate of the radio apart as mentioned above. Mine specifically was the navigation unit radio! Its a bit of a process and a very delicate job so please be careful to not pull hard on anything, if it sounds like too much of a hassle to do but you really want to get it done I can try to guide you! It does involve DE-soldering AND soldering. If not, mailing it to me is also an option I can fix it as well! I hope this thread helps someone else!
To Volume control problem
