Park position switch replacement
Old Jun 8, 2016 | 01:52 PM
Monstar's Avatar
Monstar
Default Park position switch replacement
Has anyone gone through the trouble of replacing just the switch itself that closes when you put an auto in park? Car is an 05 and the lever seems to not want to stay on which then causes problems with the car not being able to shift out of park once started. I know the switch itself isn't available from GM but it's just a limit switch. It should be a simple job to replace it. Just thought I would check in case some else has done this.
I'm not wanting to bypass the switch or the park lever/paw.
Old Jun 8, 2016 | 02:45 PM
EVRose's Avatar
EVRose
What exactly do you mean by "the lever seems to not want to stay on"?
Old Jun 8, 2016 | 03:04 PM
Monstar's Avatar
Monstar
The lever on the micro switch that is depressed when the shift handle is moved to park.
Old Jun 8, 2016 | 05:44 PM
EVRose's Avatar
EVRose
I've never heard of that switch going bad on here but if you can read any numbers on it I'm sure you could get a replacement on line somewhere like amazon.
Old Jun 8, 2016 | 05:48 PM
windyC6's Avatar
windyC6
What is/was the lever made of ?? Was it a material that you could maybe epoxy or ad some type of extension too ?
Old Jun 8, 2016 | 05:52 PM
Monstar's Avatar
Monstar
Those were my thoughts as well since I'm quite capable of changing a switch out so long as I can get my hands on one.
The lever is metal but it wants to keep popping off at the pivot so I can't really attach it any better than it already is.
Thanks!
Old Jun 8, 2016 | 06:02 PM
windyC6's Avatar
windyC6
Thanks!
Don't be so quick to give up...esp if you can't find a replacement. A little good ol fashion "J-RIGGING"...(LOL)....can go a long way sometimes....Good luck....
Old Jun 9, 2016 | 12:30 AM
Dano523's Avatar
Dano523
Which one?
As for the mod when you are having the problem and don't want to have to buy a whole new shifter assembly, is to just disable the park lock instead.
Old Jun 9, 2016 | 06:50 AM
Monstar's Avatar
Monstar
There's a limit switch behind the shift handle in that picture, Dano, that closes when the shifter is placed into park. That's what I want to fix. I don't want to disable the park lock even though that would be easier.
Old Jun 9, 2016 | 07:30 AM
C6ToGo's Avatar
C6ToGo
I thought it was the solenoid that goes bad and not the switch that triggers the solenoid?
Old Jun 9, 2016 | 09:05 AM
Monstar's Avatar
Monstar
More than one issue can occur in this area. You're right. However, in my case, it's the switch. I've already been in there once to fix it.
Old Jun 9, 2016 | 10:23 AM
unclecookie's Avatar
unclecookie
Can you take a photo of it? Or can someone post a schematic of it?
Old Jun 9, 2016 | 01:35 PM
Monstar's Avatar
Monstar
I don't have access to a photo of it. There is a photo of it in the PDF that's been linked on the site for fixing the lockout mechanism.
Old Jun 9, 2016 | 06:11 PM
Dano523's Avatar
Dano523
Photos' would help to see what the problem is to start with.
Connectors can be bought from Mouser if one of your is broken, and as for even the solenoid, most of the time it can be repaired as well.
Hence it just a 12V electromagnetic coil, but does have a thermal fuse it it, with either the problem being a wire connecting that broke, or just the thermal fuse needing to be replaced instead.
Hence to check the solenoid, just put a multi meter to it two connector tab, and make sure that you have a resistance reading through them to start with.
As for the front switch, again Mouser has connectors if your is falling apart, or if the switch, not that had to pull it apart to clean the connectors, then put it back together again.
Old Jun 10, 2016 | 03:22 AM
Pinky...'s Avatar
Pinky...
Originally Posted by Dano523
Which one?
Is that possible for a 2007 as well, or is it only the 05' old style shifter?
Old Jun 10, 2016 | 03:52 AM
Dano523's Avatar
Dano523
Your kidding right???
Its just a standard micro switch, so pulling one apart to clean it's contacts, then putting it back together is a snap.
http://siber-sonic.com/electronics/microswitchrep.html
Or you can just by a new micro switch from Mouser electronics to just place the switch instead.
Note, pull the brand and part number off the switch and cross reference at the mouser's web site for a replacement of the same one.
Also to point out, some of the times the switch is fine, and it just the arm that may need to be re-tweaked instead.
As for the solenoid,
If the pin is moving freely in the body and is not the problem and needs to be cleaned (just has the light spring pressure pushing it back forward, then a snap to first check the terminal for resistances across them, and if the unit has none, then bank that it thermal fuse went south. Hence solenoid in hand, you just need to cut the slice the wrapper off so you can get to down to the wires coming off the coil and thermal fuse in line (one coil wire soldered directly to the connector terminal, and other coil wire is soldered to a thermal fuse wire, and the other wire off the thermal fuse is soldered to the other terminal connector tab), and figure out which is the problem that needs to be corrected.
Old Jun 10, 2016 | 10:32 AM
RICH 28's Avatar
RICH 28
I tied the locking tab back years ago, but if all I have to do is clean the micro switch contacts to make it work properly, then that would be a better way to go. I will wait till someone else has done it with success before I take my center console out again. Subscribing to this thread.
To Park position switch replacement
Old Jun 10, 2016 | 11:25 AM
EVRose's Avatar
EVRose
We're talking about two different things here. When it's stuck in park the solenoid is not releasing and is at fault and has nothing to do with the microswitch. The microswitch tells the car the shifter IS in park and when that fails you get the warning "shift to park" on the DIC. That's the way I see it anyway but maybe I'm wrong.
Old Jun 10, 2016 | 12:13 PM
RICH 28's Avatar
RICH 28
I'm not so sure. The OP talks about getting the shifter out of park and not putting the shifter into park. I don't know, but maybe the OP will clarify.
Old Jun 10, 2016 | 01:12 PM
EVRose's Avatar
EVRose
Yeah, I know and I'm actually thinking he has the same problem with the solenoid everyone has when stuck in park and the microswitch just happens to be broke too.
If that microswitch really is broken there should be a message on the DIC that says "Shift To Park".
