Frame rust
Old Jul 21, 2016 | 01:57 PM
Alex Annapolis's Avatar
Alex Annapolis
Default Frame rust
Just bought an 05- love the car. Of course, after a few days im finding her flaws... Noticed some rust today where the side rails meet under the hood. I was reading scraping it off will further the amount of rust in the long run? I was going to scrape it off then paint it
Old Jul 21, 2016 | 02:23 PM
Patsgarage's Avatar
Patsgarage
It looks like rock salt in there, I would clean the entire underside of the car then see how bad it is. If you expose fresh metal to the air without painting it rust will form almost immediately.
Old Jul 21, 2016 | 03:24 PM
Bruze's Avatar
Bruze
To all you Desert Rats and Southern Rednecks:
This is why us Northern Rednecks hibernate our Vettes in the winter.
Old Jul 21, 2016 | 03:41 PM
dmk0210's Avatar
dmk0210
Yep. People think I'm crazy when I'm washing the under belly and engine compartment of my WRX during the winter. This is why.
Old Jul 21, 2016 | 04:39 PM
ErnieN85's Avatar
ErnieN85
Your local hardware store should have a product called rust reformer. Use that after removing the loose stuff (wire brush) then repaint with an epoxy primer Eastwood dot com should have all the right stuff
Old Jul 21, 2016 | 05:15 PM
choppychop's Avatar
choppychop
FYI... Plastidip will paint ON rust and stay. Get at Home Depot. I would defiantly pressure wash tho
Old Jul 21, 2016 | 11:46 PM
Garry in AZ's Avatar
Garry in AZ
I used a product from Eastwood called "Rust Encapsulator" on a 46 Ford truck frame. It worked well, and has been on the frame for almost 8 years. Comes in brush and aerosol versions. Good stuff, and I'm sure there are others.
Garry
Old Jul 21, 2016 | 11:59 PM
owc6's Avatar
owc6
Yikes!
I'm afraid to look on my underside, now!
Old Jul 22, 2016 | 08:25 AM
dshamrick's Avatar
dshamrick
If it is not directly exposed to sunlight and UV Rays I have used a product called POR15. It is fantastic.
Eastwoods Rust Encapsulator is good as well.
Old Jul 22, 2016 | 08:40 AM
Orion2011's Avatar
Orion2011
A-zone used to sell some stuff that would turn rust into black primer. Not sure if they still sell it or not.
Old Jul 22, 2016 | 09:00 AM
wayback's Avatar
wayback
have done the whole underside of my 51 IH pickup with POR15. Great stuff.
Just don't get any on you as there is nothing that will remove it. You just have to wait till your skin flakes off and sheds it. Ask me how I know.
Old Jul 22, 2016 | 09:01 AM
Alex Annapolis
Originally Posted by owc6
Yikes!
When posting this thread, I was hoping I was going to get replies like
"Ah not too bad" or
" mine was the same way "
Ah, what can you do, I guess that's what happens sometimes when you buy an older car.
Hopefully I don't find too much more when I get up in the air
Old Jul 22, 2016 | 09:36 AM
Alex Annapolis
On a more important note, is this something I should have re-welded? Just follow the bead with another one on top? Obviously I'll know more after I remove the rust - hoping it doesnt go any deeper than it appears -but I know people in the business that can take care of that for me
Old Jul 22, 2016 | 09:43 AM
Orion2011's Avatar
Orion2011
No, cosmetic mostly. Just stop the rust from getting any worse.
Old Jul 22, 2016 | 09:46 AM
Bruze's Avatar
Bruze
The problem with driving in brine slush is it gets EVERYWHERE. Including inside the frame, nooks, crannies, etc.
You should have looked at it closer before buying, although that doesn't help you now.
Old Jul 22, 2016 | 09:49 AM
RoadkingC6's Avatar
RoadkingC6
No i wouldn't go in there with a welder, i would do as the other's have said clean it up maybe get in there with a wire brush on a drill then chemically clean it, and i would just brush paint it this way no overspray gets on any areas you don't want it to. IMO the rust is not nearly bad enough to warrant welding or any other invasive procedures. a good cleaning and paint and you won't have any problems.
Old Jul 22, 2016 | 10:17 AM
Alex Annapolis
I'm definitely disappointed in myself for not noticing this upon initial inspection of the car
I think I was so overwhelmed with Corvette fever and awestruck at how clean the car was .... It was like some Jedi mind trick
To Frame rust
Old Jul 22, 2016 | 10:45 AM
dmk0210's Avatar
dmk0210
That's just going to hide it, not fix it.
It's just surface rust now. Get it off and then protect the area to prevent future rust.
Get under the car with a bright flashlight and inspect every nook and cranny for more rust.
Eastwood has good stuff. I'd start there.
My experience with Por15 was not good. Maybe I did something wrong, but I've had rust come back on parts I used Por-15 on. (this was on a Jeep, so it saw much more abuse than a Corvette)
Old Jul 22, 2016 | 11:24 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
We drove our C5 through five Chicago winters on the GY winter (not A/S) runflats, no longer available. When we sold it, the frame looked better than OP and the body/paint looked like any other C5 with the same miles and years. So OP's pictures are not encouraging.
On our C6, we park it when the salt first hits the roads and don't drive it until the spring rains melt the salt away. Except, once each winter we cover the shipping slots with duct tape and drive to Florida, remove the tape and wash underneath thoroughly when we get there. I did forget to do the tape job one year.
Recently I bought a tiny video camera and was able to look inside the frame through the shipping slots, found only one small spot of rust. I think rust inside the frame is much harder to deal with, so if OP wants to keep his car for a long time, I'd recommend the interior camera inspection. He might be ok, or not. Here's the link to my other thread, post #4 has the best info.
https://www.corvetteforum.com/forums...yesterday.html
Old Jul 22, 2016 | 12:31 PM
beaversstonehaven's Avatar
beaversstonehaven
Clean it up, paint, enjoy the car and don't worry about it.
