door latch or switch?
Old Aug 1, 2016 | 06:02 PM
mjfox's Avatar
mjfox
Default door latch or switch?
How do I know if my door switch is bad or the solenoid is bad?
I press door switch window indexes but door is not released.
any part numbers or pricing for these two parts.
thanks mike
Old Aug 1, 2016 | 06:10 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Why don't you swap out passengers to drivers and see what happens, it only takes few minutes to swap, two screws.
This way you will know if it pad, which you can buy from e-bay cheap.
This what pad looks like and here is link for replacement.
http://www.ebay.com/itm/2005-2013-Ch...tUoKHr&vxp=mtr
Old Aug 1, 2016 | 06:23 PM
WW7's Avatar
WW7
There are instructions on here somewhere on how to clean the pad to made it work properly.. There's also videos on Youtube.....I cleaned mine in about 15 minites, works fine now.....WW
Old Aug 1, 2016 | 06:29 PM
enventr's Avatar
enventr
I cleaned one and bought a new one so that I have a spare to play with
Old Aug 1, 2016 | 11:06 PM
Huskerman's Avatar
Huskerman
2021 C6 of the Year Finalist - Modified
....if not the pad then the door latch is getting lazy......not that hard to change out.....pricing on the part can vary......let us know how changing or cleaning the pads work out......
Old Aug 1, 2016 | 11:18 PM
torquetube's Avatar
torquetube
That sounds like the latch.
Old Aug 2, 2016 | 12:51 AM
scottaolsen's Avatar
scottaolsen
It's really kind of simple.
If the inside switch opens the door, then the outside switch is bad.
If the outside switch opens the door then the inside switch is bad.
If neither the inside or outside switch open the door, the latch is bad.
Old Aug 2, 2016 | 07:38 AM
Huskerman's Avatar
Huskerman
....Ya....easy peasy......
Old Aug 2, 2016 | 07:40 AM
WW7's Avatar
WW7
"Showoff"...........WW
Old Aug 2, 2016 | 07:48 AM
Mad*Max's Avatar
Mad*Max
thanks mike
it's the latch
Old Aug 2, 2016 | 04:03 PM
mjfox's Avatar
mjfox
Default latch
Originally Posted by Mad*Max
it's the latch
anyone know latch part #
thanks mike
Old Aug 3, 2016 | 12:29 AM
Grimlock13's Avatar
Grimlock13
thanks mike
Depends on driver side (88956758) or passenger side (88956721)
http://www.cultragfactoryparts.com/a...-hardware-scat
To door latch or switch?
