Amsoil= Awesome
The startup of Amsoil were some ex Mobil1 Engineers, trying to make a better product. They've withstood the test of time very well, I don't recall ever hearing a complaint about any of their products either.
Remember, the C6 and its components were designed in the early 2000s, and introduced in 2005. Synthetic fluids were hardly new technology in 2005, and GM specs synthetic engine oil, so it's not like the engineers of the drivetrain hadn't discovered synthetic gear oil. It had to be a specific technical reason they chose NOT to spec a synthetic and I don't accept the argument they didn't know. As an example, Here is a cut/paste from Tremec's site on FAQs:
Q: Why not use a synthetic fluid? A: Some brands of synthetic fluid contain powerful detergents and additives that can prove harmful to your transmission's synchronizers. While many synthetic fluids perform very well, in most cases, we do not recommend their use. Furthermore, they may void your warranty. For peace of mind, remember that TREMEC conducts all of its OEM validation testing using conventional fluids without issue.
I want to be clear, this is not an attempt to discredit Amsoil. I have no idea what formula Amsoil the OP was sold to replace the factory trans fill, and he can put whatever he wants in his car, even peanut butter and jelly if he's convinced it is better for the trans than GM's spec. I am more interested in how owners make their choices. Amsoil = Awesome is an emotional statement. I can accept it as such, but so far, I am not getting the sound technical reason for the change.
As for why I switched to Amsoil. Several high end race teams, shops use it in their vettes. Richie Rich at Abel suggest it for any car that sees performance use and he is the service manager at one of the top GM dealers in the country for vettes. He races his own z06, and uses amsoil. Anyone making big power isn't using stock fluid. For a stock car, factory is more than enough, and fine, but for extreme uses, and adding 10-200% more power, you may need a fluid that has better protection properties.
The difference is - GM is on the hook for failures, which is NOT good for their wallet. If they choose components with high failure rates or low MTBF, then they're going to spend a lot of money on warranty claims....and, hopefully, we're not going into the "planned obsolescence" conspiracy theories now.
Does "Richy Rich's" performance cars even come close to resembling the components in a factory stock Corvette? How many times a year does RR rebuild his transmission/diff/engine, etc.? This is the argument I see all the time - Someone else uses it so I do too. That is not a sound technical decision. I didn't presume the OP was in a maintenance routine that could be compared to a full race car.
I don't want to raise tension here and we're dropping into the abyss, so I am going to drop it at this point. I think I have the answer I was seeking and I wasn't looking to change minds.
Changed my ZR1 tranny to Amsoil Torque Drive fluid a year ago. 4 qts is what you need for any of the Tremec tranny drain and refill. Torque Drive was recommended over the standard Amsoil ATF product. Both are DEXRON III fluids (not DEXRON VI which you don't want to use in a Tremec manual).
I'd like to hear the details about the motor oil; but more importantly, the details comparing Amsoil product(s) to the Gm recommendations on the Trans and diff fluids.
It would be helpful in better understanding what convinced you to make the change....Thanks.
When I first bought my brand new vette in 01/13 I started using Mobil1 up until I saw the report. Maybe a little more than a year ago.
:wooh oo:
but back to oils
http://rankerreview.com/top-10-best-quality-motor-oil/
https://www.pepboys.com/accessories/...filters/brands
:wooh oo:
but back to oils
Pennzoil Platinum may not offer the absolute best performance, but for the money, it's hard to beat. This synthetic oil still performs very well and is much more affordable and easier to find than higher-end synthetics such as AMSOIL, making it the all-around best synthetic oil choice for most consumers. Read Full Review Pennzoil Platinum Full Synthetic Motor Oil
Widely considered to be the best synthetic oil money can buy, AMSOIL would be the #1 choice if it weren't for its high price tag (nearly double that of Pennzoil Platinum) and the fact that it's harder to find unless you're ordering online. AMSOIL synthetic oil can withstand extreme temperatures and holds up very well under extended drain intervals. If you want the best and don't mind paying for it, it's the way to go. Read Full Review Like I stated, the best oil for MY car is Amsoil. Bust everyone has their own opinion as to what oil is best for their car.
WRT burglars, I still have some .357 mag loads that I rolled decades ago with green dot. I think they are more potent now than when fresh.
For my .270, I like a nice IMR4831
Lubes are difficult to compare, as they keep changing their formulas, and the manufactures keep specs close to their vests. All oils / lubes have to have certain ASTM, API type tests done, but not all voluntarily report those results, publically. Amsoil does, AFIK.
Engine oils Specs such as VI, HT/HS, Noack, TBN, FP, flash, etc. Then the main streamers wanna comply (might be mandated?) to meet specs to prolong catalyst life, so the additives like ash, zinc, phos etc., are also changing - again, for emissions, not engine longevity.
Last decent spec comparison I've seen was the motor oil bible, and that's almost a decade old now, meaning suspect or out of date. I've tried to do it recently, and it's too hard to compile all the specs on a spread sheet, LOL. I just buy Amsoil...
The stuff that people rant and rave about as being fake synthetic starts out as dino oil, but goes through extremely severe processing called hydrocracking to remove all of the aromatics, sulfur, and nitrogen in dino oil. Those are the bad components, and they are totally gone, literally to zero, in the “fake” synthetic. There is only one type of molecule left that is somewhat worse than the “real” synthetics, namely naphthenes. But those molecules aren’t nearly as bad as aromatics, sulfur, and nitrogen, and there aren’t many of them anyway. So if you said the “real” synthetics were 10 and dino oil was 1 on some scale of quality, the “fake” synthetics would be about 9.8 or 9.9. So in the infamous Castrol/Mobil lawsuit, the judge ruled that the “fake” synthetics could call themselves full synthetics.
Once that was done, everyone started using various mixes of the “real” and “fake” synthetics in what they marketed as full synthetic oil. There is no oil out there any more that is 100% “real” synthetic. Not Amsoil, not Redline, not Pennzoil Platinum, not Mobil 1, not any of them. They all use blend of “real” and “fake” synthetics. Two factors are most important in making them better than dino oil, and the two things are equally true of both “real” and “fake” synthetics. They both have zero aromatics, sulfur, and nitrogen, and they both have very high VI, which means they do not need much, if any VI improver additive, which isn’t very robust, and is the biggest single Achilles’ heel of motor oils.
What is marketed as a synthetic blend, as opposed to a full synthetic is different and inferior. Rather than being a blend of “real” and “fake” synthetics as described above, it is a blend of synthetics and dino oil. The dino oil brings in non-trivial amounts of aromatics, sulfur, and nitrogen, and because its VI is lower, requires much more of the non-robust VI improver additive.
So my advice to people is to use a full synthetic, not worry about the “real” versus “fake” synthetic issue, but also not confuse it with oils marketed as synthetic blends, which really are inferior. As to which brand of full synthetic, I stay out of that one. Some people swear by the boutiques like Amsoil or Redline, while others go with the big oil companies. I personally prefer the latter because they have bigger budgets to do actual engine testing, but I don’t think you’ll go wrong with any of them. Pretty much any full synthetic is going to be better than any synthetic blend or dino oil, and since even with dino oil, oil-related failures are rare, odds you will get in trouble with any full synthetic are very low.
Thanks for taking the time to write all that up..
