I added NPP mufflers and NPP in a box to my 2012, and worked great for a few months now for some reason it sounds like it struggles to stay closed at speeds 40-50 mph
Would you install the NPP again or do something different?
I would definitely do it again, its awesome being able to control the exhaust. Quiet or loud at the touch of a button.
The only thing I would do differently is not buy a used set of NPP. I would probably get the billyboat fusions.
I had a shop hang the mufflers, but I installed the NPP in a box kit myself. The kit install is pretty easy, after you get past the vacuum hose part.
As far as the problem I am having with mine, I am not sure what is wrong. I checked my hose connections, and they are all securely pushed on all the way. Either the box is going bad, or I have a failing actuator.
