It's official! GM clearly has a "run out the clock" warranty
After numerous calls with GM Customer Experience to try to resolve the ongoing electrical issues with my Vette, this is what they have consistently stated:
1) Yes, we acknowledge that the electrical issues you're having started when the car had a full year of warranty left.
2) Yes, we acknowledge that you repeatedly took your Vette into two different local authorized GM repair centers in an attempt to get it resolved.
3) Yes, we acknowledge that the root cause was never found, hence never repaired.
4) No, we can't fix this for you now because your warranty has expired and it's not our problem. Have a nice day!
Can you guess which company has permanently lost my business?
The following 2 users liked this post by GCRoberts:
Amicon (09-30-2016),
BillytheKidder (09-29-2016)
It was multiple visits.....probably around 6 or 7 in total to two different dealerships. Only one time was the car exhibiting the symptoms when I brought it in. I showed the service manager the message on the display. He turned off the car and scanned for codes and the scanner returned absolutely nothing....and I watched him do the scan. Most other times, they would be scanning based on me reporting that it had just happened in the last few hours (or day in some cases). The scans would show random data (mostly body codes). Of course, when it was under warranty, they wouldn't bother swapping out anything based on the body codes because they thought it was a symptom of a low voltage....and they were probably right. When you have an issue like this, they tell you when it happens, bring it right in....don't bother making an appointment. But all that really gets you is another diagnostic scan by whoever they can spare to come out and do it.
By the way your making it sound is that they did not generate a repair order (I am a service advisor BTW) No repair order = no documentation which is a HUGE NO NO. We get in trouble if we do that here. Sounds like they verified the problem but it was an intermittent failure. Meaning they reset the system and cleared the light and recommended to monitor. If they did make a repair order then there is a trail of the compliant with verification and with my company depending on how long you have been out of warranty sometimes they will goodwill it. 6-7 visits with all those repair orders if they verified it every single time and didn't fix your problem then Chevy should step up. If no repair orders were made that is dealership error.
I wonder if they ever called their help tech line if they have one. I'm sure they do. That many visits under warranty techline should have been contacted and possibly the DPSM (district parts and service manager). Just some info for you.. but might be dealer fault or maybe their customer service is exactly what you say.
I've really resisted taking legal action, giving GM every opportunity to handle this ethically. But unfortunately, I think the time has come. Luckily NYS has strict lemon laws from what I've heard.
I totally understand why GM (or any car manufacturer) would want to play hardball when someone is trying to get warranty work covered after the warranty has expired, but this is clearly a case where they couldn't resolve the issue when it was in warranty. I can't believe I'm even having to argue this with them.
This is painful too, other than the stupid issues I've had with this specific Vette, I LOVE Vettes. But as a matter of principal, I'll never give GM another dime of my money if they screw me over. I don't think I can justify the expense of a Porsche, I guess I'll have to settle for a Dodge Challenger or Ford Mustang...UGH!!!
Trust me Porsche has problems as well. Like intermediate shaft bearing failures and rear main seals going out. Not to mention the extra cost. My last Mustang burned up due to an electrical fire. I still can't wrap my head around buying a Fiat (Challenger). Fix it all the time and fix it again Tony issues for sure. I hope you can find a way to get your car fixed soon. Be persistent and you will find a way.
Received 1,675 Likes
Have you talked to the GM Factory Rep for your area?
I've thought about that, but it's not me. Legal action isn't me either, that's why I've resisted so long. But if I let this ride over the winter while my Vette is stored away, I'm worried that GM will look at that as 4 months where I didn't report the problem.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
I seldom say "lawyer" but in this case....I say "lawyer." And, for all I know, it may be a little late because w/in the warranty period is different from beyond it. And, yes, I do understand the issue started during that period.
I think the problem here is with the dealers instead of GM in general.
I used to have an 03 Monte Carlo with a GM extended warranty. I brought the car to a GM certified shop multiple times because of harsh noise coming from the top end of the engine, but they were never able to duplicate what I was hearing. Finally, after my warranty had expired due to 2k miles over the 60k it covered, the top end self-destructed and I was barely able to drive the car to the shop just a couple blocks from my house. They called GM, explained that I had been bringing the car in repeatedly for top end noise, and GM agreed to replace the engine. The entire cost was covered by GM and I was one happy customer.
I've had a case number opened up for weeks. The statements I made in the opening post are from GM....not the authorized service centers.
Ask for a manager, and if necessary, the manager's manager. As long as the dealers documented your visits and what you were bringing the car in for the warranty should cover it.
I think you're right. In the end, I just want to be treated fairly and with the respect that I've earned by making the purchase. If they could just resolve the issue, I could probably even forgive the fact that I've spent approx $800 of my own money to resolve a warranty issue. But GM will NOT admit they have any responsibility to fix the issue. The most they will ever offer is that if I keep taking it to authorized dealers and keep spending money on more and more diagnostics.....that maybe they could help cover a small portion of the expense. I could spend thousands of dollars on those diagnostics and get nowhere!
