Cold start noise!
Cold start noise!
I have a 08 c6 a6 that i bought back in March,on cold start it makes a noise until the oil temp gets up to about 80 degree's and it goes away.The car has an A&A kit long tubes cat bacs 66,000 miles.Just noticed the noise as the weather has got cooler and just changed the oil.Thanks for any thoughts KLW.
It's hard to diagnose without hearing the noise but I would check the exhaust bolts. One of my cars had a ticking noise when it was cold. After awhile after it warmed up it went away. The reason was one exhaust manifold bolt was loose. I tightened it and the noise went away. Let us know your findings and good luck
You're awfully vague about what kind of noise you are hearing. How about expanding on that a bit?
First thought lifter noise but i can hear the noise more from inside the car and underneath with drivers side door open.It also is very minor at idle.Makes louder noise 1200 1500 rpms and above.Goes away at about 80 degree's oil temp.Not sure if it is an oil temp issue or a time frame issue as far as the noise going away.Checked header bolts all nice and tight.As soon as i get it off the floor will check other exhaust bolts.
I do remember a few years ago, before the S/C install, I had a similar noise at cold start up. My car was basically stock (CAI) and I added two treatment of BG44k power enhancer in the gas tank to remove carbon build up and it worked.
Other than that, my car runs great!
Follow up on cold start engine noise.Talked to corvette guy at the local dealer,he ask if i had changed plugs and i had so went back through them to make sure they were tight.That made a small difference,also changed oil and filter added a half a quart of Marvel Mystery oil and no more noise at all.I'm thinking maybe a lifter was not pumping up just right and the MMO cleaned it up.Was not sure about running it in the LS3 but have used it in lots of other stuff for years noise gone happy camper.
