No start...
Old Nov 18, 2016 | 07:01 PM
AV8TOR536's Avatar
AV8TOR536
Default No start...
Got a 2005 and lately when I hit the button..nothing,if I disconnect the battery and reconnect,I hear a click and the car will start,also before I have a no start I notice my steering wheel is not locked but after the battery disconnected and reconnected,the click I hear is most likely the steering wheel lock engaging because when I get back in to start,it's locked and it will fire up,what can I do so I don't have to do the battery deal?
Thanks!
Old Nov 18, 2016 | 07:43 PM
oemtech's Avatar
oemtech
Veteran: National Guard
Pull the battery and have it load tested. Check your alternator output. Check your grounds. Check your start wires.
Old Nov 18, 2016 | 07:48 PM
EVRose's Avatar
EVRose
Sounds like the beginning of the colum lock malfunction. Do a search on that. There is a column lock bypass that will fix it.
Old Nov 18, 2016 | 11:44 PM
bassman50's Avatar
bassman50
Originally Posted by EVRose
Sounds like the beginning of the column lock malfunction. Do a search on that. There is a column lock bypass that will fix it.
Both of these are very good suggestions, but start with the car's battery and charging circuit first. A weak or dying battery can manifest itself in a myriad of ways with the C6.
Steve
Old Nov 18, 2016 | 11:48 PM
Welker1's Avatar
Welker1
Steve
To No start...
