Exhaust system problem
Old Nov 18, 2016 | 07:46 PM
Biggarlick's Avatar
Biggarlick
7th Gear
Default Exhaust system problem
I have a 2008 Corvette Coupe with the upgraded NPP exhaust system. It usually does not open until around 3,000 RPM but lately has been opening and remaining open at various times regardless of RPM. This will last either the entire drive or at some point will return to normal operation. I have checked the fuse and it is fine. What could be causing this and what do I do to correct it?
Old Nov 19, 2016 | 11:22 AM
Landru's Avatar
Landru
I suspect problem lies w/ a bad solenoid valve.
See below link:
https://www.corvetteforum.com/forums...-the-time.html
Either a DIY fix or a dealer can do it, although dealer labor rates stink.
If this isn't something you're comfortable doing and want to avoid being gouged, hopefully there's one or more local independent HP shops familiar w/ C6 & NPP who'll replace this solenoid at a reasonable cost.
Not really a big deal in the world of C6 repairs, solenoids go bad so it's posted often enough. G/L.
Old Nov 19, 2016 | 11:29 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
A long shot, but...
Does the car have a MTW or other switch to directly control the NPP?
Old Nov 19, 2016 | 11:59 AM
mikeCsix's Avatar
mikeCsix
I haven't had to troubleshoot this system yet, but it seems to me the problem might be a vacuum leak and relatively easy and inexpensive to repair.
Old Nov 20, 2016 | 04:43 PM
rado63's Avatar
rado63
I believe you need to check three items. the vacuum lines first for any damage, not holding vacuum. Then the exhaust tail pipe flow vacuum solenoid, then the exhaust tail pipe flow control module. Do an advanced search and their will be a bunch of threads on this subject.
Old Nov 20, 2016 | 11:50 PM
Biggarlick's Avatar
Biggarlick
7th Gear
Originally Posted by Gearhead Jim
A long shot, but...
No. It is completely stock. The exhaust works fine at times and remains open at times.
Old Nov 20, 2016 | 11:53 PM
Biggarlick's Avatar
Biggarlick
7th Gear
Thank you. Will try to find more info on how to check these out.
Old Nov 21, 2016 | 12:15 AM
LMB-Z's Avatar
LMB-Z
If I were a betting person, I would bet the solenoid has gone bad. Pretty simple replace. About $50. Behind passenger side inboard tail light.
To Exhaust system problem
