LS2 Cam help!
BTR Stage IV Cam719$: http://www.briantooleyracing.com/bundle-cam-kit.html
LS7 Lifters115$:http: //www.ebay.com/itm/like/331538365922?lpid=82&chn=ps&ul_noapp=tru e
C5R Timing chain250$: https://www.summitracing.com/parts/c...FZFcfgodS8cE3A
Oil Pump upgrade150$: http://www.lingenfelter.com/product/MEL10296.html
ATI Balancer 150$: https://www.summitracing.com/parts/a...FYpefgodzCkK3A
This is everything I have and think I should change is there anything else i should do to have a more reliable car with this cam or changing anything while Im at it like the rockerarms? i have 72k miles and allot of beating miles i guess.
if i should get a new rocker arm set which ones should i get thanks guys!!
My other mods are full z06 exhaust with gutted cats and getting a vararram intake with ported TB and intake.
What do you guys think i can make to the wheels with these mods its a 2007 manual ls2 c6 vert
thanks again!!!
Chris, looks good. I installed a ATI unit when I did my cam swap close to a year ago and they are an awesome unit. Also add a ARP balancer bolt, they are stronger and longer than OEM one. The link you posted of the ATI balancer is just the replacement hubs and your timing chain set is a little pricey. Just purchase everything you need from BTR, give them a call and tell them your plans and they will set you up. Another thing to consider is upgrading your intake manifold to a FAST 102 unit to optimize your cam.
