Why a CAI
Old Dec 8, 2016 | 08:09 PM
corvettecolin's Avatar
corvettecolin
Default Why a CAI
All the posts about increasing HP say to put in a CAI, but my question is why? it places the air filter in the same place as the original so why is it better? I can understand changing from a paper to a K&N.
Old Dec 8, 2016 | 08:35 PM
Dcasole's Avatar
Dcasole
Cold air intakes like a VARARAM that truly bring in air from outside ( the Vararam pulls cold air from just under the bumper in the front ) instead of breathing the hot under the hood air thereby lowering IAT ( Intake Air Temp) which in turn keeps your car from pulling timing especially when it is extremely hot out
The other knockoffs that do not actually pull cold air do nothing ... if you have an LS3 and are not doing a VARARAM or other TRUE cold air intake ... keep your stock intake and don't waste your money on the imposters
Dave
Old Dec 8, 2016 | 08:48 PM
ringo11's Avatar
ringo11
I think there's more to it than just inlet location. An increase in air flow as well as the management of that air is crucial, particularly around the MAF sensor and into the throttle body. As you can imagine, the amount of improvement is proportional to how well or poor the factory unit performs, as it is with exhaust systems, intakes, heads, etc.
Old Dec 8, 2016 | 09:03 PM
corvettecolin
Dave
Thanks Dave, I see now that there are a lot that call themselves CAI but in fact just hang an open element in the same place which does very little.
Old Dec 8, 2016 | 09:15 PM
Dcasole's Avatar
Dcasole
Welcome !
Old Dec 12, 2016 | 07:59 PM
hrt vlv's Avatar
hrt vlv
Stock for me, You answered your own question when you ask WHY
Old Dec 12, 2016 | 08:15 PM
LowRyter's Avatar
LowRyter
I like K&N filters for flow and reuse. They can pick up a couple of horsepower on motorcycles. Doubtful it will make any power difference in a stock LS3. The reuse factor makes sense.
Some of the folks here that have mod'd their cars will tell you that an air intake mod won't make any difference until you cam and header it. I have no first hand experience.
Old Dec 12, 2016 | 09:40 PM
HOXXOH's Avatar
HOXXOH
Paper filters filter best and are cheapest, but are throwaways. K&N filters are close to the bottom in filtering ability, but flow the most air. OK, running without a filter flows more.
Old Dec 12, 2016 | 10:55 PM
LowRyter's Avatar
LowRyter
yeah, I like K&N filters. Reusable and flow.
Old Dec 13, 2016 | 08:18 AM
Boomer111's Avatar
Boomer111
And the LS3 uses the same filter as the more powerful Z06.
The LS3 flows just find the key here is the cooler air being added.
Also the maf sensor is very finicky on air flow changes.
It is not uncommon to experience some surging however slight.
Old Dec 13, 2016 | 11:05 AM
pahlbfishn's Avatar
pahlbfishn
if it flows more air it flows more dirt into your engine.
Old Dec 13, 2016 | 11:17 AM
Welker1's Avatar
Welker1
I like and have been using K&N for decades on my vehicles, both filters and CAI systems. I have NEVER had a problem and like their 'reusability'. As far as getting anymore/less 'dirt' in the engine, I would like to see one factual piece of proof of this when used properly (i.e. not over oiled). I have never had any engine issues with any of the vehicles I've used them on; some of these vehicles have had in excess 150K miles on them with the K&N filters/CAI when I sold them in great shape.
Old Dec 13, 2016 | 11:37 AM
Corvette_Ed's Avatar
Corvette_Ed
Originally Posted by Boomer111
The LS3 flows just find the key here is the color air being added.
What color?
What if you're color-blind?
Old Dec 13, 2016 | 11:38 AM
LowRyter's Avatar
LowRyter
I sold my Camaro with 165k miles on it with a K&N prochrager kit, the engine was strong and didn't burn oil.
I have three bikes with K&N filters, 80K, 62K and 34K miles respectively and I haven't seen any detrimental effects.
Now do you have any evidence to the contrary or is this supposition? And by your logic as the filter gets dirtier it filters more dirt.
Old Dec 13, 2016 | 11:53 AM
Mike's LS3's Avatar
Mike's LS3
As "Dcasole" already mentioned, a true CAI brings in ambient air preventing engine temps from entering the air intake which will pull timing.
K&N filter media may vary depending on the aftermarket CAI manufacturer's required specs. In other words, CAI brand "X" with a K&N filter may have different media requirements than CAI brand "Y".
Old Dec 13, 2016 | 12:05 PM
Unreal's Avatar
Unreal
A good intake is less of a restriction, and that is the primary gain, not the air temp going in.
People also do it for looks.
Old Dec 13, 2016 | 04:57 PM
Boomer111's Avatar
Boomer111
Originally Posted by Corvette_Ed
What color?
Oops corrected.
To Why a CAI
Old Dec 13, 2016 | 07:47 PM
C6ToGo's Avatar
C6ToGo
Poor man's CAI that my tuner says is just as effective as the $300 model.
6 bucks.
1) pry open bottom of shroud and add pvc pipe and longer bolts to maintain gap.
2) fabricate a scoop to mount there to force air into gap. Don't laugh at my black office trash can scoop....you can't see it.
3) cut a windshield sunscreen to cover the filter box area to separate engine compartment heat from scooped up air.
4) wrap a left-over piece of sunscreen around the intake tube at the MAF. Insulates intake air all the way to the throttle body.
Old Dec 13, 2016 | 07:54 PM
Dcasole's Avatar
Dcasole
Unreal, I would never disagree with you as I have a great respect for you and your knowledge but the LS3 intake and the Z06 have great intakes yet I have logs showing my car pulling timing before I installed the Vararam . After install depending on the weather it still pulls some timing but not even close to what it was pulling before the install. My IAT is now not much above ambient air temp ....
Dave
Old Dec 13, 2016 | 08:34 PM
Unreal's Avatar
Unreal
Ohh, don't get me wrong, air temps effect timing, but calling an air intake system a cold air intake is a bit of a stretch. The stock intake, haltech, etc etc etc all have similar IATs. There is other reasons besides IATs to do an aftermarket intake. So look at it as an intake system, not a "cold air" intake.
