Powder coating calipers
Where is everyone sending their calipers for powder coating. I contacted mike but he said he's no longer accepting new customers
Or where so you get new boots and seals so I can drop it off locally.
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I know someone who would do them for you but he is in Florida...he can do the seals, boots etc....he is a forum vendor as well.....if you are interested PM me
Just as an FYI for everyone about F55 heavy duty brake package.
I have a base 2009, so I ordered calipers and brackets from TPS Motorsports to do the core exchange. They showed up and looked great. Brought the car, calipers and brackets to my local shop as I'm not into working in the cold.
Come to find out the brackets sent were wrong ( my error ). Called TPS and spoke with Mike and determined I needed the Z51 brackets even though the car is not a z51. If you have the F55 brake package, you need the Z51 brackets. Makes sense, but was clear as mud prior to knowing this. Anyway, TPS should be sending me the correct brackets shortly and look forward to getting them on the car. Prior to ordering, make sure you check if you have the F55 code and order the correct package to avoid a headache.
Since you live in Indy there must be several powder coaters in the metro area. What you can do is remove the seals and pistons from the calipers and take them to local powder coat shop. You must instruct them not to coat the piston seal area which simple tape off procedure (they have a special tape). Then take the finished calipers to a trusted shop or dealer and have new seals installed. The shipping costs for calipers can be substantial due to the weight. It would be better for you to have them done locally if possible.
2020 C6 of the Year Finalist - Modified
TPS Motorsports, Mike did mine in Arctic White. I have a AW Vert and they look great. I do not track my car so white will not yellow from heat.
Understand that the buyer will have to pay shipping when he sends his original parts in, if he takes this course of action.
