Alignment for 2008 Base C6
Old Dec 27, 2016 | 12:27 PM
LowRyter's Avatar
LowRyter
Default Alignment for 2008 Base C6
Can someone give me the specs for both factory and pfadt alignment?
I'd like to see what the differences are.
thanks
Old Dec 27, 2016 | 12:32 PM
rkj427's Avatar
rkj427
Pro Mechanic
posted this today in another topic, but here you go..........
Old Dec 27, 2016 | 12:35 PM
LowRyter's Avatar
LowRyter
Thanks.....now the "recommendation" is to use the street set up?
And does it differ from the factory settings?
Old Dec 27, 2016 | 01:30 PM
rkj427's Avatar
rkj427
Pro Mechanic
yes, the recommendation is for Street set-up for maximum tire life without wearing out the inside edges, with good handling.
OEM specs. allow wider tolerances that those written here, so it is important that whoever does the alignment sets it to these exactly for best, proven results.
Old Dec 27, 2016 | 02:34 PM
LowRyter's Avatar
LowRyter
so the OEM spec is the same but wider variances?
Typically the factory variances are only there because it reflects the inaccuracies of the OEM marks, manufacturing tolerances and differences in alignment equipment.
Old Dec 27, 2016 | 03:43 PM
mikeCsix's Avatar
mikeCsix
The wide tolerance is there so they can ball park the alignment and get it off the line. The suspension has to "settle in", making it necessary to be realigned in the next couple of hundred miles anyway.
Old Dec 28, 2016 | 11:18 PM
LowRyter's Avatar
LowRyter
does anyone have the OEM specs for comparison?
Old Dec 28, 2016 | 11:37 PM
rkj427's Avatar
rkj427
Pro Mechanic
Old Dec 29, 2016 | 01:36 PM
LowRyter's Avatar
LowRyter
in comparison to factory spec as I understand it:
front
more negative camber
more positive caster
toe within factory spec at 0
rear
camber & toe within factory spec
To Alignment for 2008 Base C6
