What is this button for???
Old Jan 9, 2017 | 10:26 PM
jimfed1's Avatar
jimfed1
Default What is this button for???
Hi All. New to the forum and Corvettes in general. Just bought my first. An 05 C6. Love it. But has a button below and to the right the the steering column. Any idea what it is.
Old Jan 9, 2017 | 10:27 PM
Vet Interested's Avatar
Vet Interested
Ejection seat?
Old Jan 9, 2017 | 10:29 PM
Mike's LS3's Avatar
Mike's LS3
Aftermarket dual mode exhaust?
Old Jan 9, 2017 | 10:30 PM
4SUMERZ's Avatar
4SUMERZ
something aftermarket. Not OEM. It may of been for Mild to Wild, or similar.
Does the buttons do anything that you can notice?
jimfed1's Avatar
jimfed1
Sorry for the large picture. The fan looking button is on the right(picture is rotated 90 degrees).
Tried ejection idea and did not get thrown out of car. Any other ideas?
Old Jan 9, 2017 | 10:33 PM
cmonkey713's Avatar
cmonkey713
It could be to control anything the previous owned installed.
Old Jan 9, 2017 | 10:34 PM
ocboy's Avatar
ocboy
Is that a wide rear and narrow front?
Old Jan 9, 2017 | 10:36 PM
jimfed1's Avatar
jimfed1
Was just wondering if anyone recognized the buttons. I know they are not OEM but they must be for something. Dual mode exhaust might be on to something. Will have to try that. But have pushed both buttons and they don't appear to do anything. But have not known what to look for either.
Old Jan 9, 2017 | 10:37 PM
jimfed1's Avatar
jimfed1
Has a Z06 rear end. Love the look.
Old Jan 9, 2017 | 10:52 PM
Jon Hekking's Avatar
Jon Hekking
My last C4 had a similar setup in the console, it was used to over ride the factory stereo to an aftermarket unit behind the passenger seat through the factory speakers. Don't know if it's the same or not, just a thought.
Old Jan 9, 2017 | 11:10 PM
COvert-red's Avatar
COvert-red
well.. you have to try it with her actually over there, in the seat. Most of these things are compression switch-armed..
Old Jan 9, 2017 | 11:50 PM
ringo11's Avatar
ringo11
follow the wiring if there's any attached, see where it goes
Old Jan 10, 2017 | 12:00 AM
Bruze's Avatar
Bruze
Yes, and it probably won't work if the top is up.
Old Jan 10, 2017 | 12:29 AM
LMB-Z's Avatar
LMB-Z
I agree with Ringo...follow the wires and see where they go.
Old Jan 10, 2017 | 01:24 AM
Mike's LS3's Avatar
Mike's LS3
Since the 05's did not have NPP, look to see if two inner tailpipes have an actuator with a vacuum port that opens the exhaust valve. This will tell you that your car was fitted with a dual mode exhaust and they may not be working.
Old Jan 10, 2017 | 07:51 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I have 05, not OEM good luck in finding what it could be, but on brighter side here is owners manual on the web:
http://www.c6registry.com/Technical/manuals/2005OM.pdf
Old Jan 10, 2017 | 08:06 AM
shakinrock's Avatar
shakinrock
Have you tried to track down the previous owner?
To What is this button for???
Old Jan 10, 2017 | 08:21 AM
Sox-Fan's Avatar
Sox-Fan
If you put your location in your profile you'll probably find someone that will say, "oh, I live right by you, I can come take a look if you like."
remember to put the top down before engaging a possible ejection seat. that will save you a few bucks on a ripped top or some chiropractor fees for your passenger.
Old Jan 10, 2017 | 08:55 AM
jrose7004's Avatar
jrose7004
I haven't had that button on either C6 that I've had.
Old Jan 10, 2017 | 08:56 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
The previous owner installed something. When it came time to sell they probably removed it but didn't want to leave a hole in the dash. I expect that if you take the time to look you will find this has some wires leading out of it that have been cut. If they aren't cut they will lead to something and that is the something you are asking us to guess about.
