Wheel alignment after lowering
Old Jan 11, 2017 | 01:12 PM
kenoverbey's Avatar
kenoverbey
Default Wheel alignment after lowering
After lowering the factory bolts all the way down will there be any problem with getting the alignment in spec? I know sometime the camber won't come in if you lower it too much on certain vehicles...
Old Jan 11, 2017 | 01:31 PM
Corvette_Ed's Avatar
Corvette_Ed
I've lowered by my C5 and C6 all the way down on stock bolts and had no problems with the alignment afterward.
Old Jan 11, 2017 | 01:41 PM
LoganExplosion's Avatar
LoganExplosion
Depends. How much do you care about your tires and handling??
Old Jan 11, 2017 | 01:58 PM
Corvette_Ed
When you take it in for the alignment, bring in a copy of the Pfadt Street specs and ask to have it set to that. It's the most recommended setup here.
Old Jan 11, 2017 | 02:48 PM
LowRyter's Avatar
LowRyter
I wonder if the alignment specs should be revised once the car is lowered?
Different CofG, different roll centers, and different geometry at the attachment points. Perhaps it's too little change to matter? Just thinking out loud.
Old Jan 11, 2017 | 03:39 PM
Vet With A Vette's Avatar
Vet With A Vette
Just recently lowered my car completely on stock bolts and cut 1/3 of the rear bushing off. Had it aligned 3 weeks later to factory specs, no problem at all.
Old Jan 11, 2017 | 08:16 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Best to drive a couple of hundred miles before the alignment, so everything has settled to its final position.
Old Jan 11, 2017 | 08:33 PM
cmonkey713's Avatar
cmonkey713
If alignment has not been checked in a while have it checked these cars are sensitive to four wheel alignment. If the shop is using one of the new Hunter machines they can get everything perfect with an experienced tech running the machine. Well worth the $100 or so.
Old Jan 11, 2017 | 09:39 PM
Not So Fast's Avatar
Not So Fast
And it will "settle"
NSF
Old Jan 12, 2017 | 03:18 PM
kenoverbey's Avatar
kenoverbey
It came into spec no problem. I wasn't sure if it had enough adjustment for the camber to come back in to the nominal setting but no problem. The rear toe and camber was WAAAY out. I now know why it wanted to drive off the road during our little bout with the snow last week. I did drive a couple of weeks after lowering it so everything should be fine. Thanks for answering an honest question without being know it all a-holes like some people were on my last post.
Old Jan 12, 2017 | 04:19 PM
LoganExplosion
Yeah. My rears were waaay out after hardbar bolts. You could SEE it was off!
Old Jan 12, 2017 | 05:20 PM
Gearhead Jim
St. Jude Donor '13
Most techs don't actually use a torque wrench to tighten everything once the alignment is set, but I've seen several posts that the book torque numbers do not prevent the bolts from shifting after a while- tighter is needed, but how much?
That three-foot cheater bar would probably be overdoing it...
Old Jan 13, 2017 | 08:59 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
But yes giving it more than is the number in the book for the rear torquing is what is done by the tech I've used.
To Wheel alignment after lowering
