P2138 code need help and mechanic nj
Old Feb 6, 2017 | 07:27 PM
SBMVP16's Avatar
SBMVP16
Default P2138 code need help and mechanic nj
Need a top notch mechanic to once and for all figure out this issue with 2008 z06 reduce power message, any info would be great must be in nj
Car is in union county
Old Feb 6, 2017 | 07:37 PM
4LTVetteHead's Avatar
4LTVetteHead
St. Jude Donor '12
Wow, I hope someone can help you, have the same code. Just been a week. 2011 GS
This is all I have found.
P2138
Accelerator Pedal Position (APP) Sensor 1-2 Correlation
ECM
Old Feb 6, 2017 | 08:37 PM
RicK T's Avatar
RicK T
Could be the Accelerator Pedal itself OR a corroded connector in the left kick panel. Both have been pretty common problems over the years.
Here's the TSB on the connector:
https://www.corvetteforum.com/forums...ectorx184.html
EDIT: Here's another connector example:
https://www.corvetteforum.com/forums...this-time.html
Old Feb 7, 2017 | 08:58 PM
4LTVetteHead
St. Jude Donor '12
Don't know if this will help but here goes:
I removed the knee panel to trace the harness from the accelerator peddle. Decided to remove the Vitesse throttle controller and return stock. Started the car and check engine light is off, yes I'm happy, first time it's been off in a week. Of course, I reinstalled the controller and check engine light is still off, looking good.
Just now I decided to scan...code is still there. Check engine light is still off, have not driven due to weather. Tomorrow I will make a block and if check engine light returns I will remove controller and see if that works.
Old Feb 7, 2017 | 11:23 PM
mile-0's Avatar
mile-0
Hi guys,
Had a real problem with my car and the code described. Replaced the pedal assembly, no change. After a couple visits to my indie shop and one to Macmulkin service. Problem persisted. I decided to go after every connector in the system, and bought a terminal cleaning set from a local tool guy. I disconnected the battery, jacked the car and started cleaning terminals, beginning with ABS harnesses. Lo and behold, the worse one was the connector at the throttle body, which I discovered was not fully engaged and locked. I spent a weekend, but have not heard a chime or seen a dreaded DIC message since. I used marine electrical terminal cleaner, canned dry compressed air and light application of dielectric grease.
Old Feb 7, 2017 | 11:37 PM
mile-0's Avatar
mile-0
07-06-04-019 is the TSB number that describes this problem and discusses the connector in the driver's footwell. If you search by P2138 you will find my post and all the good info I got from other members back then (2014).
Good luck!
Old Feb 8, 2017 | 10:36 AM
Trotter's Avatar
Trotter
Call Hawthorne Chevrolet and request Giovanni look at the car. He knows vette's including the LS7 and will take the time to sit with you when you come in and go over any issues. I have been there a few times and highly recommend him.
To P2138 code need help and mechanic nj
