Headlight Removal Pix
Old Feb 11, 2017 | 07:19 PM
Rapid Fred's Avatar
Rapid Fred
Default Headlight Removal Pix
Hello all -- I recently obtained decent headlight assemblies to replace the absolutely trashed ones now on my '08.
I am looking for a clear "step-by-step" showing the easiest way to do the R&R with pix. I would prefer not to remove the front fascia as I will be working in tight quarters, and it seems folks have had success this way.
I did a search, and there was a pretty good one in 2012, https://www.corvetteforum.com/forums...requested.html
but unfortunately links to the pix don't work.
Really appreciate it -- thanks...
Old Feb 11, 2017 | 07:23 PM
rkj427's Avatar
rkj427
Pro Mechanic
the link below contains the information you need to accomplish this task............
https://www.corvetteforum.com/forums...t-removal.html
Old Feb 11, 2017 | 10:57 PM
Rapid Fred's Avatar
Rapid Fred
Thanks...
Old Feb 12, 2017 | 08:25 AM
wayback's Avatar
wayback
I found it best to have a helper. They can lift up on the front qtrs while you remove the headlight buckets.
Old Feb 22, 2017 | 10:43 PM
Rapid Fred's Avatar
Rapid Fred
The link provided by rkj427 was outstanding -- thanks!
The video at the bottom of that link (posted by Hells) was perfect -- job can indeed be done solo and without removing bumper. Of course it took me much longer than the guy in the video. Oh, and I found it helpful to jack up the car and remove the front tire, also. I'm just not as flexible as I was 20 years ago...
Old Feb 22, 2017 | 11:00 PM
rkj427's Avatar
rkj427
Pro Mechanic
glaf to to hear it all worked out for you!
To Headlight Removal Pix
