Want to get some eagle eye tailights. Do they come with the resistors needed or do you have to order them separate? At corvette mods they don't mention it . Any help would be appreciated. Thanks
They come with everything you need, except instructions. Lights are marked 1 and 2. 1's go on the left and 2's go on the right. Some of them are also marked on the back LH and RH. They are slightly curved to match the back of your C6. Ebay or Corvette Mods are all the same. About $270.00 shipped. Any questions you can PM me.
I bought mine from E-bay, comes with everything except instructions for positions of lens, they are marked for certain positions.
I should mention since they don't come instructions you connect to the black leads together, cause you can connect the other way, and then they don't work.
They are also numbered 1Left side 2 Right side, cause they have positions.
Other wise, you have sweet ride.
They are also numbered 1 & 2, cause they have positions.
Other wise, you have sweet ride. https://www.youtube.com/watch?v=an22Ndu86a0
Nice video but not completely correct. The plug that you see him attaching does not just hang there. You connect it back to the light as OEM to keep moisture out. Not necessary to start your car to check how they work either.
I'd suggest against buying anything from Corvettemods, and buy them from JW Motoring instead. Better product and better service all the way around.
Same product no matter where you buy them. JW is around 80 to 100 dollars more for the same thing, unless you buy their painted ones and that is even more.
JW's product is not the same as the others. His are made better, come with clear instructions, and he won't give you hell if you have a problem and need to exchange them as Corvettemods does.
