Head unit replacement question
Old Mar 5, 2017 | 12:41 PM
Tripleblk6spd's Avatar
Tripleblk6spd
Default Head unit replacement question
Does anyone know the settings for the PAC-Radio Pro5 when used with the stock Bose system? They say in the instructions to use the factory installed amplifier location, but doesn't tell you which one that is..... the chart goes from 1 to 9 with position 7 listing Pioneer/Other, doesn't show what position zero is....which is the default setting out of the box. I assumed position zero...but get no sound.
Any ideas? Can't find anything on their site or web searches.
Old Mar 6, 2017 | 02:47 PM
MH663's Avatar
MH663
Might want to ask the ? in the audio section.
Old Mar 6, 2017 | 05:51 PM
TorchRedFred's Avatar
TorchRedFred
If you look at the PAC module, on one side there will be two different places you can plug the harness into. One is for factory amplified Bose, the other position is used for non amplified systems. The number dial you are reffering to corresponds to the manufacturer of your new head unit. In my case 7, for Pioneer.
Old Mar 6, 2017 | 05:55 PM
TorchRedFred
These two slots. You use one or the other. It's labeled in small print on the top. One is for Bose, use the other for non Bose.
Old Mar 6, 2017 | 10:01 PM
TorchRedFred
^^^ Just to clarify, I was referring to the 2 slots on the blue module. The black thingy is the door chime module.
To Head unit replacement question
