Seat memory issues
Old Mar 15, 2017 | 11:32 AM
Buckeyefan215's Avatar
Buckeyefan215
Default Seat memory issues
i just recently purchased an 06 and I'm having some issues with the seat memory. I've gone through the settings and set up how I want everything, and gone through the display and set it up to remember on entry and exit, but as soon as I start up the car, the seats and mirrors move to the old settings. I press the number 1 on the seat memory switch and everything moves back to how I set it, but as soon as I start the car again, everything moves back. Any thoughts?
Old Mar 15, 2017 | 11:39 AM
JJLAI724's Avatar
JJLAI724
When you have your seats and mirrors and radio presets done. Hold the memory seat button on the door down for a few seconds until it "beeps". Then the memory is retained under that preset.
Old Mar 15, 2017 | 01:32 PM
Buckeyefan215
I've done that more times than I can count. Lol. I have resorted to setting all 3 seat memory positions to the same position. Seems to work so far. Think I may have a more involved electrical issue. Sometimes the radio does not come on right away. And sometimes it will show driver 2 on the dash display.
Old Mar 15, 2017 | 03:55 PM
ROJ#79's Avatar
ROJ#79
I have had memory problems with all my GM Vehicles.
Cad., GMC and Buick. If you take it to a Dealer they can reflash the Comp. It works for a while then!
Old Mar 15, 2017 | 04:02 PM
Landru's Avatar
Landru
I press the number 1 on the seat memory switch and everything moves back to how I set it, but as soon as I start the car again, everything moves back. Any thoughts? And sometimes it will show driver 2 on the dash display.
Mixing-up FOB #1 w/ #2?
Each Fob holds complete settings for each FOB, #1 & #2.
Look on rear of FOB, #'s imprinted on back.
#2 accommadates a second driver's settings providing they use #2.
Make certain you're using #1 for main driver.
Old Mar 15, 2017 | 04:06 PM
Buckeyefan215
Thanks! I'll try that. Want them to look at a couple other things as well
Old Mar 15, 2017 | 04:19 PM
stingray71's Avatar
stingray71
Old Mar 15, 2017 | 09:12 PM
Buckeyefan215
That makes sense. I am using FOB #2 because the key ring on FOB #1 is cracked. Ah the joys of buying a 10 year used car. Lol. I have noticed that you can get new FOB's, how does that work in getting them set up?
Old Mar 16, 2017 | 10:09 AM
Landru's Avatar
Landru
You're not the first member new to C6 to get fouled-up w/ this.
Wait, learning curve will continue.
For example your C6's electronics ever begin acting weird, or not at all?
If it isn't a weak/dying battery, always check cell V first.
Not a bad battery, more often than not a simple computer reset solves problem. Meaning disconnecting/reconnecting battery forcing all systems to reload.
[*Anytime C6 power's interrupted, windows must be indexed...see OM for procedure.]
A surprising # of owners do not know this trick, spend good $ on diagnostics chasing rabbits down holes.
*One senior & very respected member well versed on C6 systems insists computers reboot w/ every engine cycle. Claims a forced reboot's unnecessary, even dangerous due to possible spikes.
Problem is sometimes systems don't reboot as they're supposed to.
Remember this for the future.
Owner's Manual, need to program FOB using an OBDII programmer. Long version IIRC, somewhat a PITA. YMMV.
Many members use a dealer, of course dealers charge for this service & fees vary so call around for best price.
Many members addressed this procedure over the years, a search will turn more than one thread. This'll get you started:
https://www.corvetteforum.com/forums...-key-fobs.html
Also, YouTube probably has several videos illustrating the steps.
Have you familiarized yourself w/ FOB keys? What/when they're used, and key location? (Keys used to pop hatch to access driver's door manual release cable in case power's dead.)
Now's the time to learn before you get caught flat-footed.
Read Owner's Manual, if you don't have one copies are on the Internet.
Old Mar 16, 2017 | 12:15 PM
orca1946's Avatar
orca1946
I also have had these problems with seat memory. I have tried the above moves to no avail. I now set both fobs to my settings since my wife drives it rarely. This seems to work for me.
To Seat memory issues
