Major problem
Old Mar 17, 2017 | 09:11 PM
bigtars's Avatar
bigtars
Originally Posted by subfloor@centurytrans
If you can find somebody with access to HP Tuners I can show you exactly what to change in your tune to have everything show as ready, without having to do the stupid drive cycle.
I have an HP tuner.What do you suggest ?
Old Mar 17, 2017 | 09:47 PM
Patsgarage's Avatar
Patsgarage
I am not familiar with the HP tuner, but a Tech II should be able to test the monitors, or in some cases force them to run.
Old Mar 17, 2017 | 10:19 PM
SladeX's Avatar
SladeX
http://www.obdii.com/drivecycle.html
Unless your sensors are broken, there is no need to buy any equipment nor run HP tuners. The site above lists the conditions required to get your ODB2 readiness monitors into a Ready state.
HP tuners while used for tuning can also check the state of the readiness monitors as well as Autotap. This will save you from wasting your time doing an emissions test when the car is not ready. Unless the car is missing the sensors, even a heavily modded car will eventually activate all sensors to Ready.
Old Mar 17, 2017 | 11:53 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Thank you!
Originally Posted by ez2spd
Chuck has saved me from lighting the car on fire! After countless "shops" and tuners told me " that's as good as it gets " I was about to say enough is enough!!! Chuck sold me AutoCal and together we were able to troubleshoot! Best investment to date, not only the AutoCal but with Chuck!!
THANKS CHUCK!
THANK YOU BRIAN!
Chuck CoW
Old Mar 18, 2017 | 08:44 PM
buckmeister2's Avatar
buckmeister2
Originally Posted by bigtars
I meant heated 02 sensors. It has been driven. 25 miles , 50 miles, 100 miles. Still the same. No check engine light came on. AND no codes to erase and start all over again. I took it to Chevrolet dealer for the problem. Same result. NO codes. Even their high dollar scan machine show the same as my hand -held scan tool. NO CODES to reset. They are puzzled also. They ran it through Chevy recommended procedure. Same results. I simply don't know what to do. It has been trouble free for 11 years.
What did your emissions guy say is the reason for not passing? That might help...
