Major problem
Old Mar 17, 2017 | 12:02 PM
bigtars's Avatar
bigtars
Default Major problem
I am in dire need for some suggestions. I have a 2006 Base corvette. I cannot get the monitors to reset. I even took it to a specialist that deals in this kind of repair. o2 sensors, heated cats, and evap system are the problems. I really need some help. Any suggestions would great. Thanks so much.
Old Mar 17, 2017 | 12:32 PM
I Fly Low's Avatar
I Fly Low
Your post is really vague. Do you have specific codes? Symptoms?
Old Mar 17, 2017 | 01:06 PM
extrapilot's Avatar
extrapilot
Heated CATS? Maybe you mean the heaters for the 02 sensors.
You may have to drive it some if you haven't for a while and get the needed drive cycles in. Or you may have real problems setting the codes.
Sometimes this could be a sign that your battery is getting weak, have it "load" tested to be sure, new or old, could be a issue that needs to be addressed first.
Old Mar 17, 2017 | 01:09 PM
dmaxx3500's Avatar
dmaxx3500
what moniters?
Old Mar 17, 2017 | 01:13 PM
extrapilot's Avatar
extrapilot
Originally Posted by dmaxx3500
what moniters?
OBD Emissions..
Old Mar 17, 2017 | 01:14 PM
bigtars's Avatar
bigtars
Never a problem before. The codes are monitors not ready.Heated 02 sensors not ready. 02 sensors not ready. evap not ready. Cat converters not ready. will not pass emission test. (2 times)Check engine light is NOT on. There are NO CODE numbers !!
Old Mar 17, 2017 | 01:25 PM
bigtars's Avatar
bigtars
I meant heated 02 sensors. It has been driven. 25 miles , 50 miles, 100 miles. Still the same. No check engine light came on. AND no codes to erase and start all over again. I took it to Chevrolet dealer for the problem. Same result. NO codes. Even their high dollar scan machine show the same as my hand -held scan tool. NO CODES to reset. They are puzzled also. They ran it through Chevy recommended procedure. Same results. I simply don't know what to do. It has been trouble free for 11 years.
Old Mar 17, 2017 | 01:28 PM
ez2spd's Avatar
ez2spd
Has someone tried to data log it? Message Chuck COW and get an Auto-Cal... this will give you a real live datalog to review for possible issues
Old Mar 17, 2017 | 01:35 PM
bigtars's Avatar
bigtars
This is exactly what the emission test revealed. Cat converter NOT READY. Evap system NOT ready. Heated oxygen sensor NOT ready. Oxygen sensor NOT ready. Check engine light is OFF.
Old Mar 17, 2017 | 01:36 PM
bigtars's Avatar
bigtars
Thank you. I'll give it a try.
Old Mar 17, 2017 | 01:40 PM
IansInGarage's Avatar
IansInGarage
I don't know enough about HP tuners and other chevy ecu tuning software, but is it possible someone disabled emissions on the ecu and you need to have the ECU unmodded or reflagged with factory firmware.
Old Mar 17, 2017 | 01:48 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default 914-332-0049 if you need help.
Call me ant tell me about the car and where you are and I'll see if I can help you out.
Chuck CoW
Old Mar 17, 2017 | 02:02 PM
extrapilot's Avatar
extrapilot
Originally Posted by thedperrys
Trying to look at this logically, there are no errors indicated by any of the OBD systems as checked by both you and the dealer. In your sentence you, you used "emission test" in the singular. That leads me to believe the emission tester may be at fault. I would consider taking it to another tester.
This would be a good suggestion since you and the dealer are not "seeing the monitors not ready"?
Old Mar 17, 2017 | 02:15 PM
bigtars's Avatar
bigtars
I gave a call to Chuck. I think he will call me back. I sure hope so. Thanks for your suggestion.
Old Mar 17, 2017 | 02:58 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
If you can find somebody with access to HP Tuners I can show you exactly what to change in your tune to have everything show as ready, without having to do the stupid drive cycle.
Old Mar 17, 2017 | 03:15 PM
bigtars's Avatar
bigtars
Chuck CoW
I'm in the suburbs of Chicago. Round Lake, Illinois 847-740-8922 Jim
Old Mar 17, 2017 | 05:01 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default Help is on the way!!!
HELP IS ON THE WAY!!!
Chuck CoW
To Major problem
Old Mar 17, 2017 | 05:13 PM
bigtars's Avatar
bigtars
Chuck CoW
Thank you so much.
Old Mar 17, 2017 | 05:27 PM
bigtars's Avatar
bigtars
I have an HP tuner but it has never been opened. My son got it for my birthday 2 years ago. I just bought the complete deal from cow. We'll get thing fixed with his tune. After talking to him I have complete confidence in him. Smart guy. Thanks for your help.
Old Mar 17, 2017 | 08:34 PM
ez2spd's Avatar
ez2spd
Chuck has saved me from lighting the car on fire! After countless "shops" and tuners told me " that's as good as it gets " I was about to say enough is enough!!! Chuck sold me AutoCal and together we were able to troubleshoot! Best investment to date, not only the AutoCal but with Chuck!!
THANKS CHUCK!
