A clothes dryer fabric softener sheet moistened with detail spray works very well to remove the bugs and will not damage the paint. The detail spray will provide a slick surface and help prevent bugs from sticking on your next drive.
In the hot summer months when the bugs really stick like glue none of those sprays or wax will be any good without a lot of elbow grease. Absolutely nothing works as well on bug removal as used wet dryer sheets. ABSOLUTLEY NOTHING.
As I mentioned, clear bra is the best way to remove anything and everything. I washed my car this past Sunday and it had some dead bugs I hadn't noticed from December when I last drove it before winter hibernation. Hosed it down good and washed it with good ole soap and water on a sponge, came right off with no problem at all. And no, I didn't wash the car before I put it away for the winter because it didn't need it. Just never noticed the dead bug splatter, my fault.
In the past i have used dryer sheets and simple green. Car is currently ceramic coated so bugs are no longer a problem.
I agree on the ceramic coating....I detail my ride fairly regular and the ceramic coating has been awesome. I normally just hose down the bugs, let it set and then wipe off. If I come across a tough spot like tar or bugs that have been baked on with this harsh MS sun....just let it soak longer and hit it with a bit of bug/tar remover, wipe and spray wax the spot.
Spray water on bugs. Let sit, spray more water on bugs. Then spray more water. Then use car washing liquid with a microfiber towel and wash. You are not going to hurt the paint. Its protected by clear coat. When finished washing and rinsing, apply wax of your choice. In between waxes for minor cleanup, spray with detailing spray. You can also spray bugs with detailing spray, let it sit a few minutes, then wash bugs off.
I agree. Keep it waxed and wet it down when you are done driving. You can also drape wet towels over the front and let them soak...wipe right off.
Meguirers Ultimate Detail spray. Spray on, let it sit a little, wipe it off along with the bugs and leaves a nice shine.
That's all I use to clean up my car before I park it to let people look at it. I use Honda spray on my motorcycle to clean the bugs, and Plexus for the windscreen. I love the smell of Honda spray. It's too expensive to use on something as large as a car though.
I travel the intestate constantly and pick up a lot of bugs as well. Here's what's worked for me for years:
1) I keep a good coat of wax on my vehicles and use a spray detailer after every wash.
2) Prior to actually washing the car, I soak/spray the front bumper and windshield down for a minute or so; depending on how bad the bugs are, I may repeat this a couple of times.
3) As I wash the vehicle, I rinse the whole car down as I do each section, insuring I hit the bumper & windshield.
By the time I get to the bumper and windshield, the bugs come off with very little effort. I have never had to use any type of special bug remover.
Exactly, except I don't use the detailer. Getting those bugs soft is key, then soft rag wetted with water and car wash soap takes those soaked down bugs right off. Even Love bugs in FL, which are the worst. If you keep your car outside, morning dew works great at softening.
