C6 Wheels
Old Apr 11, 2017 | 02:29 PM
C Richard's Avatar
C Richard
8th Gear
Default C6 Wheels
want to go to 19 & 20 inch wheels. adding supercharger 550RWHP. having trouble finding wheels that will fit Z51 09 C6. need more rubber on the ground HELP!!!!
Old Apr 11, 2017 | 03:01 PM
Corvette_Ed's Avatar
Corvette_Ed
Wider tires is what you need, not taller wheels. You can go up to 305 width on a base model on the rears.
Old Apr 11, 2017 | 03:16 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
If your having traction problems, going to a 20" rear wheel may not be the best approach.
Why? ... Because the larger in diameter the wheel is, the smaller the tire's 'Aspect Ratio' is going to be. In other words, a tire that has a small aspect ratio such as a 25 or 30 series tire has hardly any sidewall (think driving on rubber bands).
And since there is so little sidewall, there is no flex in the tire during launch.
Ideally, you want as much sidewall as you can get. This will give the rear tire lots of flex during launch.
Look at the trailered drag race cars ... They all have smaller diameter wheels (15" or 16") that have wide / fat sidewalls.
That's what you NEED in order to launch that supercharged Corvette real HARD !
Make sense ?
_____________________________________
Here is a photo of what I'm talking about (16" diameter rear wheels with drag radials ... with a fat / flexible sidewall)
Hard launch and lots of tire flex:
To C6 Wheels
