Exhaust Change question
Old Apr 15, 2017 | 01:42 PM
C6Sal's Avatar
C6Sal
Default Exhaust Change question
I have a C-6 with this exhaust chrome plate:
https://www.corvetteforum.com/forums...1&d=1492278086
I just purchased this after market Axle back system:
Does anyone know if I will still be able to put the chrome plate back on with the new exhaust? The specs say the tubing is 2.5 inches.
Old Apr 15, 2017 | 06:02 PM
paulrichy's Avatar
paulrichy
i dont think you will know for sure till u put the new axleback on, but the tips arent welded to the mufflers so you do have adjustment.
Old Apr 16, 2017 | 07:43 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
I think the tips would be somewhat far away from the rear fascia.
Old Apr 16, 2017 | 08:11 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
No real way to tell until the new one's on and you try to fit the plate. jmo
Old Apr 16, 2017 | 02:37 PM
C6Sal's Avatar
C6Sal
Thanks Guys. I think the new ones are 1/2" bigger, and looking at how the plate is attached, it looks like there may be a 1/2" gap between the top plate and bottom plate. If you look close you can see there is a seam. The plate is actually two pieces. I think I can live with that.
To Exhaust Change question
