Need help... broken bolt
Old Apr 17, 2017 | 08:58 PM
Youmadbro's Avatar
Youmadbro
Default Need help... broken bolt
I was trying to torque my intake manifold bolt back to specs when I broke the first bolt. Only the thread part is stuck in the heads. I try drilling and using a extractor to get bolt out. The extractor than break and is now stuck in the bolt also. I'm tempted just put the intake back on with 7 bolt and hope it don't leaj. Any suggestions?
Old Apr 17, 2017 | 09:13 PM
Cherokee Nation's Avatar
Cherokee Nation
Add a good gastet sealer around the area of the broken bolt....Want hurt to try" Good Luck
Old Apr 17, 2017 | 09:39 PM
WulfLS3's Avatar
WulfLS3
Cruising
Can you post a pic? Depending on how much of the bolt is exposed or recessed in the hole, sometimes the corner of a small chisel or sharp pointed punch setting on the outer edge of the bolt held at an angle and hit counterclockwise with a hammer can turn the bolt out.
Old Apr 17, 2017 | 09:44 PM
pagosawingnut's Avatar
pagosawingnut
Veteran: Marine Corps
St. Jude Donor '17
Tig or Mig welder and weld enough metal on to grab onto.
Old Apr 17, 2017 | 09:49 PM
HK770's Avatar
HK770
89 inch # torque for those bolts.
Old Apr 17, 2017 | 10:23 PM
Giamanut's Avatar
Giamanut
Get the bolt out, Install all the bolts back in. If you got the extractor from harbor freight
it would explain why it broke.
Pay someone with a portable welder to build up the bolt like Pagasawingnut says.
Remember we always have time to do it over the right way!
Old Apr 17, 2017 | 10:33 PM
choppychop's Avatar
choppychop
Pull the head off and extract the bolt from the block side of the head.
Old Apr 17, 2017 | 10:48 PM
Youmadbro's Avatar
Youmadbro
Thanks everybody for the feedback. What about soldiering?
Old Apr 17, 2017 | 10:50 PM
Giamanut's Avatar
Giamanut
Nope.. weld or drill some more carefully or pull the head.
Old Apr 18, 2017 | 08:19 AM
Don-Vette's Avatar
Don-Vette
machinist here, yes that technique, works well, or drill it out and tap it with a left handed tap.
Old Apr 18, 2017 | 10:04 AM
choppychop's Avatar
choppychop
Once you get the bolt out be advised torque to INCH LB not foot Lb.
Old Apr 18, 2017 | 10:07 AM
Sox-Fan's Avatar
Sox-Fan
It also never hurts to put your location in your profile. Someone nearby to you might be willing to come help.
Old Apr 18, 2017 | 10:49 AM
IansInGarage's Avatar
IansInGarage
This is to small of a bolt to weld something on top of it, or with my welding experience with MIG i'd never attempt it. Plus extractors most of time are not "just" steel. So not even sure if you can weld on it. Breaking a bolt is easy, breaking a extractor is nightmare. I'd say your options are:
1. Grind it flat or just make sure the extractor left in head isn't bigger than original bolt. Bolt up intake manifold as normal and check for leaks after installation. If you are lucky, the one bolt missing won't cause a vac leak. Usually you hear leak, but also spraying starter fluid around area that your concerned with seal while engine is running and being scared of RPMs raising (vac leak).
2. Remove head and take to machine shop to extract.
Old Apr 18, 2017 | 11:11 AM
choppychop's Avatar
choppychop
#2....
Or once you have the head off you might just be able to turn the bolt out with a pair of vise grips's from the other side of the head...
If it was my car I'd take the head off and do it correctly, quit screwing around.
Old Apr 18, 2017 | 12:04 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
oopsie
Old Apr 18, 2017 | 01:41 PM
RagTop69's Avatar
RagTop69
#1??? Seriously??? Why not just duct tape it? OP, take the head off and do it right.
Old Apr 18, 2017 | 01:53 PM
Welker1's Avatar
Welker1
If you don't, you'll most likely end up with bigger (more expensive) problems down the road
To Need help... broken bolt
Old Apr 18, 2017 | 02:00 PM
Corvette_Ed's Avatar
Corvette_Ed
As the old saying goes...
**** in one hand and hope in another and see which one fills up first.
You need to pull the head and do this job right. Reinstalling with 7 bolts will eventually lead to a leak, and that's not a matter of "if," but when.
Old Apr 18, 2017 | 02:29 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Flex-seal
Old Apr 18, 2017 | 08:21 PM
Dcasole's Avatar
Dcasole
This is to small of a bolt to weld something on top of it, or with my welding experience with MIG i'd never attempt it. Plus extractors most of time are not "just" steel. So not even sure if you can weld on it. Breaking a bolt is easy, breaking a extractor is nightmare. .
Absolutely 100 % Agree ... not a shot in HE##LL at welding anything to the top of that skinny bolt let alone the broken extractor .... there is not enough " Meat" to try and tap it out with a chisel either
Take a chance and try it with just one bolt , what do you have to loose ? if not , don't make things worse , take the head off and take it to a machine shop
When I changed my manifold out I started each one of those bolts and spun them in as far as I could by hand , then used my inch pound wrench to finish the job , most the time I will make a second pass at torqueing the bolts but with these ... I left well enough alone
Good luck and let us know how it turns out
