Lost keys, getting new keys
I know, there are a bunch of threads out there but I haven't found one that deals with losing both keys and being locked out of your car. All the instructions I've read require you to sit in your car, push this button, push that button.... but if I can't get in my car that's no good.
So, since I have no key... I'm going to the dealer to have a new one machined as well as getting a new fob.
I assume this new key will get me in the car (the little key entry under the "trunk" lid)? Won't this set off the alarm? If so, how the hell would I turn it off with a non-programmed fob?!?
Assuming the alarm doesn't go off (yeah right) ... From there I can proceed to do the steps to program the fob myself?
Thanks in advance for clarifying this... which I'm sure will be the millionth time asked. Sorry. I'm really trying to avoid towing my car to the dealer, because I don't trust tow companies with my vehicle or their prices.
I have not lost my keys so I don't know if starting the procedure will stop the horn blaring or not so I would be ready to pull the horn relay or the wires at the horn itself. Here is a link to the fob reprogramming procedure;
https://www.corvetteforum.com/forums...tructions.html
Here is a post about the horn circuit and relay under the hood:
https://www.corvetteforum.com/forums...dead-horn.html
Let us know how it goes.
When we recently got our C6 it only came with 1 key and 2 #2 Fobs. One of the fobs was quite beat up from being bashed around on a key ring. With my previous experience of the wife losing her key I wanted to avoid a another trip to the dealer so I had a couple more keys cut and also found a brand new #1 Fob on ebay for $69. I now have a proper #1 and #2 fob and key for each. The beat up one will be an emergency backup if needed.
one hidden fob wrapped in foil in the trunk..one hidden key somewhere on the car outside...
From what I read on this forum, the FOB's are exactly the same regardless what number is printed on them. The number is just so you can tell them apart. The first FOB you program is #1, the 2nd #2. You could program #2 FOB as the first FOB if you wanted.
We have have five vehicles and three motorcycles, each with two keys. One key is kept where we keep all of our keys when we use them. The 2nd set of keys are in a lockbox so in case lost a or misplaced a key, we get it out of the lock box.
The horn should stop after ~2 minutes or less ( this is designed to stop honking in order to protect your battery).
Do NOT shut the door after that until the programming is complete.
Yep. I ordered "a bunch" of spare fobs from online because of the great inconvenience I have caused myself. I wish the dealership would have given me some advice regarding this when I bought it, particularly not leaving my fob on the same ring as my metal key................
Received 1,136 Likes
why would the alarm go off if you unlock the car with the key?
Once the hatch is open, you need to pull the wire in the storage area and simultaneously open the door with your hand. If you don't, the door will remain semi-latched. BTW- it's not the little handle that opens the gas door.
IIRC, t's the act of opening the door with the handle in the trunk/hatch that sets the alarm off (same as opening the door with the floor handle when the car is locked), which is why the fob programming instructions tell you to open the driver's door before inserting and turning the key to start the programming, but, you have to get the door open first.
"Today the Supreme Court overturned the lower court's ruling that upheld "Laurel vs. Hardy," which had held that the plaintiff must comply with Statute #007, which vacated the previous ruling by the county court which upheld that the defendant was within his right to deny service."
So I found my keys...
My 3 year old put it in her purse, well hidden among black checker pieces............
Well I am so glad I don't have to reprogram any keys. I am so glad I put-off going to the dealership and paying damn year $200 if I was unsuccessful.
*wipes brow of sweat*
Thanks everyone for your suggestions and help. I know what to do with the spare FOB and Key that I ordered.
jmeirhofer (04-23-2017)
But don't try to change the battery in the car, wait till you get home. It contains many small parts just waiting to literally spring apart and get lost.
Not quite yet. Take the battery out of the spare FOB you hide and you won't have to wrap it in foil and the battery won't leak in the hot car ruining the FOB. If you ever need to use it, just get to it (you have to get into the car some other way whether it has a battery or not), put the spare in the glove box slot where it works just fine without a battery, and drive to the closest Wal-Mart to get a battery for it. This is where I keep my spare batteries.
Location: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
I also keep a fob stashed and a spare key hidden.
Getting locked in once is enough for me to learn.
Now I have to figure out a plan for my new DD that has a key start and is the funny key. Like a switch blade. It's big and bulky.
Have onstar now so no need to worry lolol. I know problems.
