Just got an Exhaust Ticket in Los Angeles... What now?
I just got a ticket in Los Angeles for my exhaust.. I took out the mufflers and swapped the H pipe for an X pipe
Is it a fix it ticket like the old days? Or is it different now?
Will they ask to look under the hood when inspecting?
How do they inspect it, do they use a db meter or just look to see if there are mufflers?
Other than buying stock exhaust and installing, What do these tickets cost? Some places say there no longer fix it and you just pay a fine? Need some advice.
It says 27151 (a)cvc-loud under reason for ticket
UPDATE!!!
Took care of everything
CHP no longer does Exhaust inspections for los angeles, so you need to go to a referee station Which are not police officers so they cannot cite you if they see something else illegal like tints or no license plate.
went to referee station with stock exhaust on, limit is 95 decibels, I hit 88 decibels. Made sure oem engine was under the hood, didn't say anything about my tints,no license plate, or ram air intake. Passed, gave me paper to take to court.
How do they do decibel test?
they test both sides, so since corvette is quad exhaust tips they put a line in the middle from each side at a 45 degree angle away from the car about 1 foot or 18 inches, didn't ask how long it was i'm guessing from watching, and at the same height that the tail pipes sit, then they rev the car to a specified RPM that the government states, which is different for each car, for 2005 c6 it was 3750 RPM, they slowly rev it up to 3750 and let go of throttle quickly, they do that to both sides and if they are both under 95 decibels you are good. If for any reason you car cannot Pass this test and it is Unfixable, you must pay the full fee which is 400-600 dollars.
Rules they states was, mid pipe can be anything H, X, or true dual, Must have oem cats, and must have some sort of mufflers that hit below 95 decibels, doubt any aftermarket ones will in my opinion since stock was hitting 88
Mandatory Costs
$108 referee inspection
$25 Fix it ticket
My personal costs
$220 used oem exhaust/mid pipe (didn't need mid pipe)
$125 extending pipes since the stock ones I bought were a bit short, and installing stock one
The day after I put on my muffler delete pipes easy peasy!
UPDATE!!!
Mandatory Costs
$25 Fix it ticket
My personal costs
Snowflake cop!
Don't have to worry about these types of things in TEXAS
More info needed. The ticket should state if it is a fine or needs to be signed off.
By removing the mid pipe did this delete the 2 cats?
What is meant by "taking out the mufflers"?
Are you running no exhaust mufflers now?
Good luck.
Received 3,633 Likes
2016 C6 of Year Finalist
Exactly! Was it a noise ticket? Did not meet emissions ticket? What?
I got a 'no front' plate ticket for my last vehicle, a fix it ticket. I zip-tied the plate to the front, took a picture and showed it to the judge who dismissed it. Promptly removed the plate when I got home. Front plates look so bad on some cars, it's worth the risk of the ticket..
Is it a CHP or city cop.
If it is a CHP you will have to take your car to the check station to get signed off.
If it is a city cop, find some cop friend and he can sign it off for you.
to sign off CHP ticket you will have to add mufflers and cats if you dont have them.
I got a tint ticket and it was just a fine. Apparently there are two sections that it could be written up in. One is tint and the other is under stickers. He was nice and wrote in in the sticker law, or he din't know the law well. CHP too.
Front plate tickets are always fix it!
I got pulled over in Houston for having glass packs and straight pipes in my old Camaro. Put on a new exhaust system later the same day. Went to court and showed them the receipt that I immediately took care of the problem. The fine was dismissed.
Q: Is it a fix it ticket like the old days? Or is it different now?
Depends what you did in total. Do you still have cats? Do you have a CARB certificate for the exhaust?
Q; Will they ask to look under the hood when inspecting?
They may or may not. That's up to them so be prepared.
Q; How do they inspect it, do they use a db meter or just look to see if there are mufflers?
Again, depends on what you did in total. They may ask you to have a SMOG inspection performed where the technician will look for cat delete, improper mods, etc.
Q: Other than buying stock exhaust and installing, What do these tickets cost? Some places say there no longer fix it and you just pay a fine? Need some advice.
If you deleted the cats it might be more than you expect. Depends on the jurisdiction and what exactly you did.
If you drove around a car with mods you took the risk. Although, I thought LA was pretty easy on folks but maybe things are changing. Best of luck to you...
This was published a few years ago and may still be the standard for measuring an exhaust system for noise level in Cali. I've only talked to one WA State LEO that had any idea about how to perform this measurement.
SEMA Action Network
In some states, noise limits for modified exhaust systems are established by a SEMA model bill (attached) and applicable to an easy to administer test standard. The SEMA model provides for the testing of vehicle exhaust noise to a standard adopted by the Society of Automotive Engineers (SAE) with an established noise limit of 95-decibels (SAE J1169). Under the SAE standard, a sound meter is placed 20 inches from the exhaust outlet at a 45-degree angle and the engine is revved to three quarters of maximum rated horsepower. The highest decibel reading is then recorded.
To date, with the popular support of vehicle enthusiasts and related businesses, the model has been enacted in California, Washington State and Maine. This year, the SEMA model was introduced in Virginia.
95 dBA- 20 inches away at a 45 degree angle- rev to ¾ max hp.
This measurement can be made with a smart phone loaded with the right app. Judging by the description of what you did to your exhaust (removed mufflers), it will not pass this test.
**** poor excuse to write you up, IMO. Good Luck.
SEMA Action Network
Received 2,093 Likes
Received 3,088 Likes
2021 C6 of the Year Finalist - Modified
Where is the OP ? ? ?
He never came back to this thread he started
