Exhaust
Just make sure you get the correct headers / x-pipe for your GS. Be advised that there is a difference in the x-pipe for the GS vs the Z06, so get the correct one that fits the GS.
Also, you can get the x-pipe with or without cats ... my suggestion is to get the x-pipe with the cats.
The Borla mufflers will bolt right up to the ends of your x-pipe without modification as long as you get the correct mufflers for the GS.
Also, you will not need to use the rear O2 sensors, but you will get a check engine light if it's not 'tuned out' when you have the car dyno tuned. You really need dyno tuning to take full advantage of the headers.
In my case, I was worried about exhaust 'drone' at highway speed with the Borla "S" mufflers, so I opted with the Borla "Touring" mufflers ... Even if you were to just replace the stock exhaust manifolds with headers, the car will be slightly louder even if using the same mufflers.
BTW .... I am using Pfadt headers on my GS:
________________________________
On the Pfadt headers, the headers connect to the x-pipe using aircraft type V-band clamps:
Also, the exhaust is real smelly on these cars that run without cats.
But, it's your call.
I have the S Type II axle back with stock manifolds and pipes. I sounds great and I can confirm there is no drone. I doubt it would drone with headers and X pipes but can't say for sure. I love the deep throaty sound and the burble when you let off.
Now making 492 whp and 410 rwhp. Corvette World of Dallas did the work and they are
the best in the business. Great work!
Is that the only performance mods you have done? You gained 62hp by just putting on headers and X Pipe with a tune?
Something is very wrong here ... Is 'Yarbie' talking about Net HP or RWHP?
410 RWTQ is believable ... 492 RWHP is not believable at all ... not at all
After installing a set of Pfadt headers with catted x-pipe and a dyno tune, I got 405 RWHP / 401 RWTQ on the same dyno.
That's an increase of +34 RWHP and +37 RWTQ
_____________________________________
I don't have the initial dyno sheet (when bone stock), but here is the dyno sheet after installing the headers and catted x-pipe with tune:
Attachment 48338516
And there is little to no HP in any of those CAI / filter units.
But, a cam change will put you over the 500 SAE Net HP (flywheel)
