Obdii
Old May 8, 2017 | 04:09 PM
corvette312's Avatar
corvette312
Default Obdii
Hello Members,
On my 2007 C6 Coupe L2 with 38 k miles. I got the engine warning light today. When I went to put gas I noticed that the cap was lose. So after I put gas I install it correctly but when I started the car again the light was still there. Question, where do you connect the OBDII and second question, once the OBDII is connected and supposedly there is no other issues, how do you reset the engine warning light?
Old May 8, 2017 | 04:36 PM
TorchRedFred's Avatar
TorchRedFred
In my other cars, when this would happen with a loose gas cap, it would usually take a little while to clear. If you are sure that was the problem, loose gas cap, just drive it for a bit and it should clear on it's own.
Old May 8, 2017 | 04:42 PM
Cherokee Nation's Avatar
Cherokee Nation
Originally Posted by corvette312
Hello Members,
Disconect the neg battery cable for about 10 seconds and see what happens.
Old May 8, 2017 | 04:44 PM
unclecookie's Avatar
unclecookie
I agree with TorchRedFred. If the gas cap was the problem, then the light should clear on its own after so many start cycles.
Old May 8, 2017 | 04:51 PM
jwswanson's Avatar
jwswanson
Hello Members,
The connector is directly below the steering column. You can use the code reader to clear the code but it won't pass a safety inspection until it has been driven for a while and the ready code is set you Y. Just driving for the necessary time will clear the initial code and make it ready for an inspection.
John
Old May 8, 2017 | 05:15 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
That's your answer ...
Old May 8, 2017 | 06:03 PM
corvette312
Thank you everyone. I will try all of the above- a step at a time. I shall return and report.
Old May 9, 2017 | 03:29 PM
corvette312
TorchRedFred, you're right the engine light cleared this morning. Thanks.
To Obdii
