Manual Trans Fluid Question
Old May 15, 2017 | 08:32 AM
TRK8's Avatar
TRK8
Default Manual Trans Fluid Question
Hey Guys,
I was wondering how often do you change your trans fluid, and do you change it or just top it off?
I wanna change it because on high rpm's I have a hard time shifting to forth, but as for regular driving, it's fine...
Old May 15, 2017 | 09:13 PM
GMJim's Avatar
GMJim
Originally Posted by TRK8
Hey Guys,
Manual transmission fluid is fill for life (as per Tremec engineering) but I change mine every 6 years or 50,000 miles. Kinda just because of my OCD.
Old May 16, 2017 | 01:09 PM
CadVette's Avatar
CadVette
I changed my fluid at 35,000 miles. Glad I did. The fluid was turning into a dark brown color. I like a nice pink in my girl.
Old May 16, 2017 | 01:28 PM
WW7's Avatar
WW7
Mine was changed at 75,000 and it needed it bad , it was black... After the fluid change the trans shifted much smoother and the problem I had with it going into second gear when cold disappeared... Change it out!!!......WW
Old May 16, 2017 | 01:30 PM
Travlee's Avatar
Travlee
i changed mine at about 25k miles, gave me peace of mind knowing that i did it.....yeah i know i was way early, but oh well.
Old May 16, 2017 | 01:51 PM
cclive's Avatar
cclive
Be sure to use fluid compatible with Dexron III and not Dexron VI.
Old May 16, 2017 | 02:32 PM
dmk0210's Avatar
dmk0210
For you guys that changed it, what fluid did you use?
Old May 16, 2017 | 02:34 PM
Unreal's Avatar
Unreal
Amsoil Torque Drive ATF
Old May 16, 2017 | 02:36 PM
Travlee's Avatar
Travlee
i used redline in the trans and diff
Old May 16, 2017 | 03:35 PM
WW7's Avatar
WW7
I used the stock GM fluid,the same that came in it from the factory...WW
Old May 16, 2017 | 09:43 PM
CMY SIX's Avatar
CMY SIX
BG products Syncro-Shift II you will not believe how quiet the car will get
Old May 17, 2017 | 08:22 AM
BlindSpot's Avatar
BlindSpot
I have no basis to question the hours of engineering development/testing from GM/Tremec engineers by switching to some "boutique" oil company's alternative. GM/Tremec have "skin" in the game. They have to warranty these units, alternative fluid sources do not.
I'm not saying there is necessarily anything bad about an alternative choice, as I simply don't know, but a risk I am unwilling to take; nor, is there anything I can find to "fix" in the trans and diff, so no reason to experiment either.
Old May 17, 2017 | 09:23 PM
Rocketmanwpb's Avatar
Rocketmanwpb
I have 117K on mine and I have used both the GM fluid and Penzol Dexron VI (6) which is the same as the GM fluid. Got the Penzol from an online order through PEP Boys. I generally change mine every 50K even though as stated it is filled for life by the factory.
To Manual Trans Fluid Question
