Problems
Old Jun 11, 2017 | 06:18 AM
JRGS's Avatar
JRGS
Cruising
Default Problems
Drove my 2013 Grand Sport last night and all at one time got the following 3 warnings at once
Service Traction control
Service active handling
Engine light came on
Car ran very rough and engine had ticking noise
Car only has 2050 miles on it
Any thoughts?
Old Jun 11, 2017 | 07:48 AM
4SUMERZ's Avatar
4SUMERZ
Any thoughts?
Check for a loose spark plug wire for starters.
Passenger in the seat when it happened?
Old Jun 11, 2017 | 08:17 AM
BlindSpot's Avatar
BlindSpot
Replace the battery.....bad coil....the blue connector under the passenger's foot board....
Sorry, couldn't help it.....
Go right to the last item first, the CEL. Ignore the first two items, the AH and the TC.
AH and TC are safety systems and whenever there is a primary engine management failure the ECM will disable and send warnings on AH and TC. It does this so the driver does not "rely" on these systems while the fault exists.
Remember that both AH and TC can use various engine management functions to operate effectively. Functions such as ETC, Fuel cutoff and spark retard. After the fault is found, fixed and cleared, AH and TC will be restored. Nothing needs to be done with them.
Old Jun 11, 2017 | 08:26 AM
Mad*Max's Avatar
Mad*Max
Do you have a code reader?
Old Jun 11, 2017 | 11:15 AM
Richard F's Avatar
Richard F
Check your spark plug wires....mine did the same thing, wire came off coil....
Old Jun 11, 2017 | 07:31 PM
c6 monkey's Avatar
c6 monkey
Sure sounds like a collapsed lifter to me. If that's what it is there's powdered metal all in your oil, don't run it. I hope I'm wrong
Old Jun 16, 2017 | 05:45 PM
JRGS's Avatar
JRGS
Cruising
Thanks to all.
I took off coil covers and found #6 was not connected. Put it back on, cleared the code and the car runs perfect!
Old Jun 16, 2017 | 06:18 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I'm tellin' you, these guys and gals above are GOOD.
Old Jun 17, 2017 | 01:27 PM
Dcasole's Avatar
Dcasole
Really ......
Old Jul 17, 2017 | 08:19 PM
p2toy's Avatar
p2toy
Thanks to all.
I know this thread is a month old, but the exact same thing happened to my 2011 grand sport yesterday. Plugged the wire back in and it runs perfect. For everyone else that encounters the same symptoms, CHECK YOUR WIRES before taking it to the dealership.
I was fortunate enough to find the problem, but should have checked here on the forum first. It would have saved me an hour of searching.
Old Jul 18, 2017 | 11:38 AM
Mike's LS3's Avatar
Mike's LS3
Might be worth purchasing a $50 scan tool. DTC's will usually give you direction in resolving issues.
After installing a set of spark plug wires I went for a test drive. During the test drive I developed a miss and CEL went on. I knew which wire popped off, but wanted to read the DTC. Sure enough, it directed me to that cylinder with the misfire.
Glad you resolved your issue.
Old Jul 18, 2017 | 12:47 PM
cclive's Avatar
cclive
First thing I would check...
Old Jul 18, 2017 | 05:13 PM
Vet Interested's Avatar
Vet Interested
Thanks to all.
I had the same problem 2 days ago. Turns out #5 wire at the coil fell off. Code reader founder it. Sooooo glad I bought the reader 2 years ago. First time I actually used it.
To Problems
