Disable dome light switch?
Old Jul 14, 2017 | 12:02 PM
CSixDude's Avatar
CSixDude
Default Disable dome light switch?
Almost everytime I get in and out of my car, my knee hits the dome light button and activates the lights under the mirrors, which isn't helping my battery any. Is there an easy way to permanently disable the push in function of this switch?
Old Jul 14, 2017 | 12:05 PM
Corvette_Ed's Avatar
Corvette_Ed
Easiest way would be to break the **** off with a hammer.
Old Jul 14, 2017 | 12:29 PM
cclive's Avatar
cclive
Simple, pull the dash panel and disconnect the switch.
Old Jul 14, 2017 | 01:29 PM
Homer3D's Avatar
Homer3D
Or pull the fuse for the dome lights.
Old Jul 14, 2017 | 01:36 PM
OlyC6's Avatar
OlyC6
St. Jude Donor '16-'17, '19
Strip of Gorilla Tape...
Old Jul 14, 2017 | 01:58 PM
CSixDude's Avatar
CSixDude
Well, I'd like the rotate function that adjusts the dash light brightness to stay intact, I just want to disable the PUSH function that turns on the map lights under the mirrors.
Old Jul 14, 2017 | 02:05 PM
Corvette_Ed
The only way I could think of to do that is to remove the switch, take it apart, and wedge something inside that would prevent the button from being able to be pushed in, then reassemble and reinstall.
Old Jul 14, 2017 | 02:38 PM
wayback's Avatar
wayback
You must be one tall Dude. I'm 6'3 and never hit it with my knee.
Do you have the easy exit option turned on?
Old Jul 14, 2017 | 02:59 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
"Easy Exit Option" ... What is that ... A Martin Baker ejection seat?
Old Jul 14, 2017 | 03:27 PM
wayback's Avatar
wayback
Easy exit automatically puts seat all the way back and up when stop button is pushed. Next time you enter and start up the seat goes to your programmed position. 3LT feature.
Old Jul 14, 2017 | 03:44 PM
jaki30's Avatar
jaki30
Glue a rubber o ring of appropriate thickness over the ****. This will prevent the **** from pushing in, but, still allow it to rotate.
Old Jul 14, 2017 | 03:56 PM
Vette_DD's Avatar
Vette_DD
Disable dome light switch? Almost everytime I get in and out of my car, my knee hits the dome light button and activates the lights under the mirrors, which isn't helping my battery any. Is there an easy way to permanently disable the push in function of this switch?
Never knew this was a dome light switch since none of the C6 coupes I ever owned had a dome light. My 2012 Corvette Owner's Manual calls it an instrument panel brightness ****.
Old Jul 14, 2017 | 04:15 PM
wayback's Avatar
wayback
Push it and it controlls the map lights.
Old Jul 14, 2017 | 04:18 PM
EVRose's Avatar
EVRose
Or one short dude. I've tried to intentionally hit that button with my knee and there is no way I could do it. I'm 5'11".
Old Jul 14, 2017 | 05:57 PM
CSixDude's Avatar
CSixDude
I'm not sure how I'm hitting it, but somehow I'm turning it on accidentally. I've seen numerous other complaints of the same thing on this forum, so I know I'm not the only one.
Old Jul 14, 2017 | 05:58 PM
Vette_DD's Avatar
Vette_DD
Map lights are not dome lights. My point was that there's no such thing as dome lights in a C6 Coupe.
Old Jul 14, 2017 | 06:23 PM
GREENKAR's Avatar
GREENKAR
PICKEY, PICKEY. Everyone else figured it out. And that's
To Disable dome light switch?
Old Jul 14, 2017 | 07:24 PM
CSixDude's Avatar
CSixDude
That sounds like it might work, thanks.
Old Jul 14, 2017 | 07:28 PM
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
Unplug the top of the mirror plug in. that will keep them off. Also, any other functions of the mirror. If you can figure out which wires on the plug work the lights you could snip those wires. Seems extreme. It is a PITA as I imagine most of us, I know I have, hit that switch. I just blame it on the people who make these choices when they are drunk and trying to plan the operation of the car before the build.
Old Jul 14, 2017 | 07:36 PM
Vette_DD's Avatar
Vette_DD
Originally Posted by GREENKAR
PICKEY, PICKEY.
*picky
