Fire Extinguisher
Old Aug 15, 2017 | 07:32 AM
PHILLIE PHANATIC's Avatar
PHILLIE PHANATIC
Default Fire Extinguisher
Does anyone have one in their C6, if so where did you mount it?
Old Aug 15, 2017 | 07:44 AM
Corvette_Ed's Avatar
Corvette_Ed
I have one in mine. I used the Brey-Krause fire extinguisher mount, which mounts in front of the passenger seat. I did have to have my Lloyd's mat cut and restitched to accommodate the mount, but it would work fine with stock mats without needing to modify them.
Old Aug 15, 2017 | 07:50 AM
C6ToGo's Avatar
C6ToGo
In the rear cubbie storage.
Old Aug 15, 2017 | 10:06 AM
PHILLIE PHANATIC
I should have mentioned, I have a Convertible. Can it be mounted behind 1 of the seats? If so can you screw in the bracket there safely?
Old Aug 15, 2017 | 10:10 AM
Corvette_Ed
Not sure if the Brey-Krause mount would work behind the seat. There might not be enough clearance. It uses the seat base bolts for mounting, and with the extinguisher mounted in it, there might not be enough room for it to fit. It's really designed to sit directly in front of the seat.
Old Aug 15, 2017 | 10:15 AM
J3TVETTE's Avatar
J3TVETTE
Brey Krause mount here as well. Works perfect using the Weathertech Mats.
Buy this, its a great deal.
https://www.corvetteforum.com/forums...inguisher.html
Old Aug 16, 2017 | 01:12 AM
vetten76's Avatar
vetten76
[QUOTE=slowstang305;1595365601]Brey Krause mount here as well. Works perfect using the Weathertech Mats.
Does the extinguisher bother your passenger at all when she's in the car?
Old Aug 16, 2017 | 07:06 AM
Corvette_Ed
The passenger's legs are above the level of the extinguisher, so he or she doesn't even touch it.
Old Aug 16, 2017 | 09:43 AM
Racer1735's Avatar
Racer1735
For these various extinguisher set ups, are they rigged to a heat detector so they go off automatically or are you having to pull the pin? Also, is your hose plumbed into the engine compartment or in the case of the extinguishers in the rear cubby or the passenger compartment is that where the foam is going?
Old Aug 16, 2017 | 12:10 PM
Corvette_Ed
The extinguishers are manual use, meaning you have to remove them from the mount, pull the pin, and compress the handle.
Old Aug 16, 2017 | 01:33 PM
altnaut's Avatar
altnaut
2nd Gear
Default fire extinguisher
this is mine
Old Aug 16, 2017 | 01:59 PM
Racer1735's Avatar
Racer1735
Follow up questions.....are you using basic Kibbe extinguishers that are available anywhere, or auto-specific extinguishers?
Old Aug 16, 2017 | 03:03 PM
Corvette_Ed
Mine is a chrome-cased dry chemical extinguisher that I purchased from Amazon. Dry chemical is the recommended type for automotive use.
Old Aug 16, 2017 | 04:47 PM
buckmeister2's Avatar
buckmeister2
I keep mine, which is the larger size dry-chem, in a two-box collapsible container in the rear. It is too large to put in front of the seat, but I can reach it quickly.
Old Aug 16, 2017 | 05:49 PM
vetten76's Avatar
vetten76
You're talking about a full fire suppression system that goes in a race car. All I'm after is a fire extinguisher just in case of fire with me or someone else. For my street car.
Old Aug 16, 2017 | 05:51 PM
vetten76's Avatar
vetten76
Good info. Thanks.
Old Aug 16, 2017 | 06:37 PM
windyC6's Avatar
windyC6
Looks to me like any passenger couldn't pull their legs up to the seat. What am I missing ?? You know how it is in there sports cars. Any ride of any length and most people want to be able to move their legs around a little......
To Fire Extinguisher
Old Aug 16, 2017 | 07:08 PM
pjazz's Avatar
pjazz
C6 of Year Winner (performance mods) 2019
Had an Extinguisher in front of the passenger seat on my c5 for 15 years barely noticeable to my wife or me.
Clean agent Extinguishers are more expensive but work just as well and will not leave damaging residue on the engine or paint of the car.
Old Aug 16, 2017 | 09:03 PM
vetten76's Avatar
vetten76
[QUOTE=windyC6;1595376740]Looks to me like any passenger couldn't pull their legs up to the seat. What am I missing ?? You know how it is in there sports cars. Any ride of any length and most people want to be able to move their legs around a little......[/QUOTE
Your right. Mu wife hates the extinguisher in that same place in my C3. That's why I asked that question. Not that she's big on the C6 for long drives. Lol. Leg room is important.
Old Aug 16, 2017 | 10:41 PM
J3TVETTE's Avatar
J3TVETTE
Not at all. Only complaint I have heard is lack of space to put the purse (Where she used to put it).
