Preventive Maintenance Questions
Old Aug 25, 2017 | 11:44 AM
Runner100's Avatar
Runner100
Default Preventive Maintenance Questions
My 2013 Vette coupe with a manual transmission is my first Vette. I bought it new and it has 32K miles. I just picked it up from the dealer following a new battery installation. I was told I needed throttle body service ($139.95) despite having the same service done nine months and 6K miles ago, brake system flush ($136.95), and fuel filter ($186.88). I couldn't find any mention of the recommended intervals for these or other services in the owner's manual. Every time I take my car in for service, using one of three different dealers, I come away feeling like my pocket was just picked. The car is garaged every night, is driven carefully with a mix of city and highway miles, and is usually filled up with Top Tier premium fuel.
Any thoughts on what services are needed and when??
Old Aug 25, 2017 | 12:46 PM
C6ToGo's Avatar
C6ToGo
Ouch. Glad I avoid dealers.
Getting close to the 5-year coolant drain and fill interval.
If you can do basic stuff.. TB service is removing air intake duct and cleaning with spray solvent. Easy to remove the entire TB unit to clean and wipe.
Don't know of a replaceable fuel filter...maybe '13s do. My 07 has an in-tank screen that doesn't get replaced.
Old Aug 25, 2017 | 03:58 PM
simplegto's Avatar
simplegto
St. Jude Donor '11-'12-'13-'14
You are right he is picking your pocket.
Old Aug 25, 2017 | 04:31 PM
TorchRedFred's Avatar
TorchRedFred
To the OP, do yourself a favor and just ignore the requests for service every time you go to the dealer. A lot of those service managers get paid on commission and try to sell you overpriced service to fill there own pockets. After many years I have finally found a decent dealership to service my daily driver Ram pickups. They change my oil every 2 months and never try to sell me any of those bonus services. I worked at a dealership for 1 day many years ago. No exaggeration, I walked out on my second day because I was just appalled by all the scams and stories and bragging about all the people they ripped off or took advantage of.
Old Aug 25, 2017 | 07:59 PM
cmonkey713's Avatar
cmonkey713
This is why we call them "Stealerships".
Old Aug 25, 2017 | 09:38 PM
torquetube's Avatar
torquetube
Snake oil. Especially the last one. The fuel filter is integral to the in-tank fuel pump assembly and is good for the life of the pump. Actually replacing it would cost ten times that amount in parts and labor. They are attempting to defraud you.
What is the name of the dealership?
Old Aug 25, 2017 | 10:59 PM
TonyFaub's Avatar
TonyFaub
you can test your brake/clutch fluid once in a while with a $20 moisture tester off amazon; water is not good for brake fluid so I usually flush mine once every couple years, $20max, unless I do track time then it's more frequent. the other stuff is
if it runs fine, you're fine
Old Aug 26, 2017 | 01:02 AM
the kid C6's Avatar
the kid C6
A lot? How about all? It's the industry-wide upsell.
Old Aug 26, 2017 | 04:10 AM
Don-Vette's Avatar
Don-Vette
Brake fluid flush and a and fuel filter on a 13'? seems like overkill, I did have the throttle body and injector service done on my 10' GS at 30,000 mile however.
Old Aug 26, 2017 | 09:49 AM
Sonny71's Avatar
Sonny71
Oldtimer
How dirty does the brake fluid look?
Like Tony said water is your enemy here.
The next thing on their list will be to change the DexCool after 5 years. Leave it if it's still nice and pink looking.
Fuel filter?----That would involve dropping both tanks, labor alone would be in the $1200 - $1500 range. Add a 20 ounce bottle of Techron at your next fill up and don't worry about it.
Old Aug 26, 2017 | 10:30 AM
Kenny94945's Avatar
Kenny94945
Wow...new fuel filter for under $200.
That would be a deal...maybe an $1800 discount.
Find a new dealer or service advisor or an independent garage.
I'll comment IMO a brake fluid flush every two years is good preventative maintenance.
Good luck.
Old Aug 26, 2017 | 10:39 AM
windyC6's Avatar
windyC6
YUP.....now you know why they give you free oil changes. It's so they can get you in there and give you that famous 300 PT. inspection and tell you what you need to have done. I swear you could probably turn around right after driving a brand new car off the lot and drive it into the service dept. and they would tell you you need something that will cost about $200-+....
Old Aug 26, 2017 | 01:12 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
To an extent, I agree esp. WHAT is the name of this dealership?
There is no way they can replace a fuel filter, besides giving it to you in the box to take home as a souvenir, for $187. Unless you are using #2 diesel in your tank I can't imagine needing another throttle body service, or maybe they need to positively demonstrate why you need this one, and the first one, too. About the only thing I can agree with is the brake fluid replacement (approx. every 2-3 years).
So, Who Is This Dealer? (so some can avoid it like the plague)
Old Aug 26, 2017 | 06:45 PM
Rky Mtn C6's Avatar
Rky Mtn C6
2024 C8 of the Year Winner - Unmodified
2023 C7 of the Year Winner - Unmodified
Beware when they say "Based on age and mileage, you need to . . . " That's a sure sign they're trying to hook you. I have a 2010 F-150 truck I bought new. Every time I take it in for service, I'm told my battery failed a test, and I need a new battery. They have been telling me that for 5 years, and I still have the original battery. I had the transmission serviced at 60,000 miles. Six months later they tell me my fluid is dirty and the transmission needs to be serviced. I looked at the guy and said, OK, but first refund me what I paid you six months ago when I had it serviced. The guy blushed and changed the subject.
Old Aug 26, 2017 | 10:13 PM
LowRyter's Avatar
LowRyter
go somewhere else
Old Aug 27, 2017 | 04:20 AM
LMB-Z's Avatar
LMB-Z
Just curious, but why in the world would you take your car to a dealership for a battery? 3 minutes to take out, 3 minutes to put in, done. My grandmother can do it, and she's 92. There are things I would take my car to a dealer to have done, and there are things you just do yourself. I would also request to see the old fuel filter. I bet they can't find it. Wonder what they charge to change air in the tires. Air gets stale, so you replace it every other year...$129.95.
Old Aug 27, 2017 | 07:34 AM
truckplay's Avatar
truckplay
Default sounds like a rubber stamp
some techs have a rubber stamp, they recommend the same things on every car without lifting the hood not really a dealer thing, happens at tire stores also, "everything needs shocks"
To Preventive Maintenance Questions
Old Aug 27, 2017 | 10:50 AM
windyC6's Avatar
windyC6
Definitely !!! And lets not forget that you need new filters even if your cars been sitting every since the last ones were installed.....
Old Aug 27, 2017 | 10:54 AM
JerryC5's Avatar
JerryC5
Cruise-In I Veteran
Cruise-In II Veteran
Just follow the recommended maintenance schedule in your owner's manual. All dealers want you to spend more and will recommend items. The 3000 miles oil change is a perfect example, why change until the % oil life is very low?
If you think Corvette dealers are bad for this, try any Lexus dealer. They like to add all kinds of stuff, then they may put " Declined recommended XXXXX service" on the invoice. When that happens, I write " Not a Factory recommended service" on the invoice.
Old Aug 27, 2017 | 11:59 AM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Originally Posted by LowRyter
go somewhere else
I'll second that. If they try to cheat you on one thing they will cheat you on everything.
